Author Topic: Cold start RPM  (Read 2780 times)
Benz280
  • USA, NJ, Jersey City
Cold start RPM
« on: August 07, 2022, 01:21:32 »
Trying to identify :
Originally during a cold start RPM would start at 1300 / 1400 RPM . Shortly after ( Warming up ) RPM would drop to normal 800 range. ( This is correct start )
Now, cold start is around 500 then moves up to 800 range when warm.
Replaced thermostat in WRD , no change.
Any thoughts as to what could contribute ?
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: Cold start RPM
« Reply #1 on: August 07, 2022, 13:53:04 »
Make sure that the little air filter on the WRD is not clogged.
Re: Cold start RPM
« Reply #2 on: August 07, 2022, 18:44:40 »
Stuck slide valve under the thermostat.
Benz280
Re: Cold start RPM
« Reply #3 on: August 08, 2022, 01:28:11 »
Thank you JA17 & Dr. Benz
As for air filter - Working fine , not clogged at all .
WRD pulls strong air when cold , as engine warms valve closes , when warm ( 3 Min )  no air being pulled .
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
