Author Topic: Cheap parts suppliers in Germany  (Read 5567 times)
« on: June 06, 2005, 05:33:54 »
Hi all,
I might be in Germany in the next few weeks and its time to go part shopping for some bargains (if they exist). Does anyone know of any good sources of parts in Germany (apart from MB)?
I need hardtop and soft top rubber, a new softtop, king pin kits, and potentially parts to prepare for an engine and IP pump rebuild. Also - does anyone know of any parts that are only available from Germany?
thanks,
Paul.
PaulS
Silver '68 280SL
mulrik
Re: Cheap parts suppliers in Germany
« Reply #1 on: June 06, 2005, 05:52:23 »
Try SLS in Hamburg. Website:http://sls.sparebase.de/start/index.phtml
They speak English and are very efficient to deal with.
Ulrik
« Reply #2 on: June 06, 2005, 09:14:47 »
Germany:
http://www.cabrio.de/
http://speed-autoteile.com/
http://www.niemoeller.de/
http://pagoden-center.de/
Right next door in The Netherlands:
http://www.classicsl.com/
http://www.oldtimerbv.nl/
A site listing several vendors:
http://www.superclassics.nl/mercedes_benz.htm
« Reply #3 on: June 06, 2005, 15:36:07 »
As far as I know all parts available here should also be available elsewhere in the world.
Engine parts may be cheaper in the US, where there may be 'lagging stocks' around (on which price increases from DC have not been added yet).
An IP rebuild has to be done by a properly equipped shop / specialist, who will put in whatever parts are required when he rebuilds the pump. Not sure you can even buy parts for the pump 'loose'.
Maybe check with DC first for what you need, then shop around from a few other vendors Rodd listed.
Good luck!
« Reply #4 on: June 07, 2005, 06:22:53 »
Thanks guys. Much appreciated. I'll follow up on those leads.
Paul.
PaulS
Silver '68 280SL
