Author Topic: paint color  (Read 2150 times)
cajlouni
  • USA, CA, San Jose
paint color
« on: August 11, 2022, 17:00:01 »
Hi, can anyone tell me what color my 1971 SL is? or where to find it in the Vin? (Picture attached) Its more of a deep blue.
TJMart
  • USA, NC, Matthews
Re: paint color
« Reply #1 on: August 11, 2022, 17:30:13 »
Lift up your hood and on top of the the driver side fender there is a stamped plate. Second line will give you your paint code. See this link for the paint codes in the technical manual.
https://www.sl113.org/wiki/DataCard/PaintCodes
Tony
Tony
1970 280SL, 4 Speed
cajlouni
  • USA, CA, San Jose
Re: paint color
« Reply #2 on: August 11, 2022, 17:46:38 »
This is perfect!!
Thank you vey much
Re: paint color
« Reply #3 on: August 12, 2022, 15:16:57 »
Would suspect that the car is DB 904. But the metal data plate is the place to check.
cajlouni
  • USA, CA, San Jose
Re: paint color
« Reply #4 on: August 12, 2022, 21:48:32 »
It actually had 180G or Silver/Grey Metallic ?
1971 280 SL
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: paint color
« Reply #5 on: August 12, 2022, 22:10:10 »
Could have been repainted then.  My car was originally arabian gray and a previous owner painted it signal red.  If you look inside the dash, you can usually find  the original color.
Lori
1968 280SL (US)
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: paint color
« Reply #6 on: August 13, 2022, 00:51:53 »
Also look u see your rear deck, pop it off and should have original color there on frame and pans
Robert Hyatt
Williamsburg, VA.
