Author Topic: Speedometer conversion from MpH to KmH  (Read 2719 times)
TEJOLX47
  • Portugal, Lisboa, Lisboa
« on: August 14, 2022, 12:45:34 »
Hi there,
My car is a 280SL originally delivered in 1970 in the USA.
Having bought it in Europe I decided to convert it to Euro specs, mostly for convenience.
At some point in time, I have bought a Km/h speedometer.
I was concerned about differential ratio, but went forward with the change.
After installation, I have noticed two issues: a) the Kilometers were correctly and accurately counted; and b) the speedo showed a speed about 10Km/h less than the real speed (measured with GPS).
So, on the first opportunity, I sent the speedo to recalibrate.
It came back showing a speed 5Km/h ahead of the real speed.
And, for the time, I have done nothing.
Last week, I was talking with an oldtimer MB mechanic, and he told me that to swap the Speedometer, I need to replace the instrument as well as a "part" in the engine (and he pointed to the distributor shaft).
Does anyone know anything about this?
Many thanks
Francisco
Francisco
1970 280 SL (US delivered, Auto, AC, PS)
181 Light beige with 423 Tobbaco brown top
Re: Speedometer conversion from MpH to KmH
« Reply #1 on: August 14, 2022, 14:54:09 »
Interesting comment about the "part in the engine" - the speedo is hooked to the transmission. I don't think there is any connection to the engine.
The tachometer is hooked up at the engine. There is plenty of information on the website about that.
« Reply #2 on: August 15, 2022, 19:28:33 »
No relationship to the engine. It is driven off a gear in the transmission.
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: August 15, 2022, 20:10:08 »
Hi there,
Many thanks
Francisco
At what speed does it show 5km/h ahead? In Germany, by law, the manufacturers MUST NOT install speedometers that show LESS speed than actual. As a result, all km/h speedos in German road vehicles are calibrated to show MORE than actual. 5km/h more at 100km/h is absolutely normal.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Jordan
  • Canada, ON, Jordan
« Reply #4 on: August 15, 2022, 20:30:45 »
Thanks Mike, good information to know.  Mine was originally a German road vehicle and the speedo has always shown 3km/hr more at 100km/hr.  It's irked me a bit so its nice to know that is normal.  I'm less irked.
Marcus
66 230SL  Euro 4 speed
TEJOLX47
« Reply #5 on: August 16, 2022, 10:28:04 »
Thank you all for your contributions.
@Mike,
Thank you for that valuable input.
The speedo shows circa 10 Km/h more than real speed until 80km/h.
Then it reduces the gap to 5Km/h more or less.
I will take that into consideration.
Cheers
Francisco
MikeSimon
« Reply #6 on: August 16, 2022, 21:11:18 »
There are a few other things that play into this:
- Was the km/h speedo originally for an SL
- The speedo is calibrated to match the rear axle ratio
- The wheel diameter also needs to be considered.
All these things will affect the deviation of the indicated-to-actual speed.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
TEJOLX47
« Reply #7 on: August 17, 2022, 10:45:58 »
Hi Mike,
Speedo matches the partnumber for Euro specs Speedo in the EPC;
Rear axle ratio was taken into consideration;
Tire measure is standard.
To confirm this, I have measured GPS distance and odometer distance a few times and for a few distances. They match.
I believe the only issue I have is with the real speed, and that - I was told - is set by a magnetic mechanism in the instrument.
Many thanks
Francisco
Francisco
« Reply #8 on: August 18, 2022, 08:18:16 »
Whoever calibrated the speedo for you should be able to answer your questions.
The normal routine is to make a chalk mark on the tyre and the floor, roll the car forward (or back) one wheel revolution and mark the floor again. Measure the distance travelled and give that to the speedo shop.
