Author Topic: Driving while the speedometer is removed  (Read 2543 times)
wayneesch
  • USA, MI, Dexter
« on: August 14, 2022, 16:11:46 »
My odometer is not working and I will remove speedometer and send the unit out for rebuild.  Will there be any issues driving without the speedometer unit connected while the cable remains connected to the transmission?
1968 280SL
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: Driving while the speedometer is removed
« Reply #1 on: August 15, 2022, 18:51:42 »
shouldn't be.
just make sure the cable isn't interfering with any wires in the dash.   tape it up or zip tie it to something where it that spinning cable won't wreck something.
« Reply #2 on: August 15, 2022, 19:24:34 »
The two instrument lights will be hanging loose and it you turn the lights on they will be live and could short. You can stick each one in a little plastic bag and leave them loose. In this way the metal bulb holder is insulated from the rest of the dash.
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: August 15, 2022, 20:15:20 »
Not sure there could not be a problem. I had a rotating inner cable slicing through the top metal sleeve of the outer.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
wayneesch
  • USA, MI, Dexter
« Reply #4 on: August 16, 2022, 00:19:59 »
Plastic bags for the light bulbs is an excellent idea - Thanks Joe
1968 280SL
