The question; is it the the battery, alternator, starter or the voltage regulator after incorrectly use of jumper cables having been crossed resulting in sparks flying?
BACKROUND
My battery is about 3 years old. The alternator has not been touched nor has the starter or voltage regulator in the 9 plus years that I own the car. A few months ago I took my 280SL on a shopping trip, unfortunately I left the lights on and was a result the car would not start. A friendly shopper offered to help, unfortunately he crossed the jumper cables and it resulted in flying sparks.
Ever since the above incident not having driven the car for a month or so I needed to get the car started with jumper cables. Once started I drove the car long enough to allow the battery to recharge so the car would start okay without external help. On the last three occasions having jumped the car to start and driven her long enough to start unfortunately after driving the car and parking in the garage the car would not start.
The car is difficult to handle after it was started with jumper cables the idle speed on the speedometer shows around 1,200 rpm and does not reduce during the drive. is the voyage regulator causing this?
One more item to note is that once the car stats and I drive her the headlights do work fine, does that mean the alternator is okay?
Being more mechanical than electrical I need some help to resolve this. I am thinking it might be the alternator that is the culprit, however, I am not sure.
What do you think?
If I take the car (naturally using jumper cables), to an electrical shop can the check and positively identify if it is the battery, alternator, starter or the voltage regulator?
Input from the Group is very much appreciated.
Dieter
