Author Topic: Finished!!!!! 1961 220Sb Column Shifter adjustment  (Read 10030 times)
Re: 1961 220Sb Column Shifter adjustment
« Reply #25 on: October 14, 2022, 03:19:24 »
There is a groove between the two sliding cylindrical sleeves which should be full of grease. Remove the two spring clips, slide the throwout bearing and its mounting sleeve off. You will see the groove inside the sleeve. Clean it, grease it and re-install it on the transmission tube.
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #26 on: October 14, 2022, 10:30:45 »
Thanks, this transmission seems to be in working order.  Hopefully the install will not give me too much difficulty...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Leester
  • USA, VA, Lorton
« Reply #27 on: October 14, 2022, 16:49:38 »
I put a little grease on the splines so it would slide on the shaft without any snags. Probably didn't need it but I was thinking ahead to when I would be laying on my back.   Lee
Lee Backus
1963 220SE Cabriolet
1985 500SEC
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #28 on: November 13, 2022, 00:09:40 »
I just pulled the transmission and immediately found the problem.  The top lever is flopping without engaging anything.  I pulled the cover and something is broken that engages the lever.  I'm done for the night and will investigate further.  I think I will use the spare transmission that I bought after everything is cleaned and ready to install.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #29 on: December 02, 2022, 23:19:30 »
I put the transmission I bought in the car and ran out of time so I have these clean and new parts to install yet.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #30 on: January 11, 2023, 14:58:13 »
The transmission is all back in.  I need to change the motor mounts then adjust the linkage.  All rubber part will be new so it should be setting where it needs to be for final adjustments.
 Hopefully all will work.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: FINISHED !!!!!! 1961 220Sb Column Shifter adjustment
« Reply #31 on: January 13, 2023, 20:45:29 »
Everything is back together and the linkage is on and working.  I couldn't take it for a ride since it is snowing but going through the gears seems to work correctly.  Thanks to all who answered my questions.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
bracurrie
  • USA, TN, Nashville
  • The SL to have is a 113, but I don't have one.
Re: Finished!!!!! 1961 220Sb Column Shifter adjustment W11x
« Reply #32 on: February 05, 2023, 15:29:02 »
Brad
I have a 1970 280 SE with manual column shift.  When working its wonderful.  What a luxury to be able to drive and shift without moving your right had very far from the steering wheel.
There are bushings in the steering column too.  Have you changed those?
Brad
1970 280 SE W108.018
M130.980 w/ US emissions
manual column shift
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #33 on: February 05, 2023, 15:39:55 »
I didn't pull the lower linkage from the shifter at the fire wall.  All others are now replaced with the transmission and many other parts. The shifter moves easily.  If we get a nice day with no salt on the roads I'll give it a try.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #34 on: April 21, 2023, 20:09:08 »
I finally got to test drive the car yesterday.  It shifted better than it ever did before.  I still need to get the car aligned since the suspension rebuild.  The frontend squealed terribly.  I have to get the toe in adjustment closer before I go anything further than around the block.
« Last Edit: April 21, 2023, 21:21:23 by badali »
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
« Reply #35 on: April 21, 2023, 20:31:40 »
Congratulations!  Great perseverance, patience, and general "sticktoitivness".
