Author Topic: Prep for adhering decals  (Read 2023 times)
lreppond
  • USA, CA, San Leandro
« on: August 26, 2022, 16:18:19 »
I’m going to be replacing my warn decals on speed relays with new reproduction ones. I know the proper placement or orientation but I’m not sure how I should remove the old adhesive that’s literally bounded to the tops.  I was thinking about using denatured alcohol but I don’t want to damage the relays.  Any advice?  Goo gone? Orange oil? Etc.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
Re: Prep for adhering decals
« Reply #1 on: August 26, 2022, 16:28:31 »
I have used goo gone (or similar) with good results. Be sure to clean that off with some light solvent. If you put the stuff on a clean cloth that avoids the potential for an "oops" of liquid on the relay.
GM
  • USA, CA, San Pedro
« Reply #2 on: August 26, 2022, 17:04:24 »
Peel, then WD-40
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
ejboyd5
  • Southold, NY
« Reply #3 on: August 26, 2022, 18:18:53 »
3M Prep-Sol, none better.
lreppond
« Reply #4 on: August 26, 2022, 20:02:45 »
I had both GooGone and WD-40 in my garage.  I started out with just a little spray of WD-40 on a microfiber cloth.  It took a little time to soften the adhesive but once it did it came off with not much effort (rubbing). After it completely evaporated, I wiped it down with 90% IPA.  As an added bonus, it left the plastic shell of the replay looking new.
Unfortunately, I looked up 3M PrepSol and it’s unavailable in California even though it’s water based and low VOC!  Shouldn’t surprise me!
Thanks gentlemen for your suggestions.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
DavidAPease
  • USA, CA, Chico
« Reply #5 on: August 28, 2022, 00:04:55 »
Len,
I'm very fond of a good IPA,  and have even brewed a few decent ones myself,  but using one in this way is a new idea to me!   ;D
      -David
-David Pease
« Reply #6 on: August 28, 2022, 02:38:48 »
I have used a 3M product in a spray can that is quite good, gentle on paint surfaces and available here in CA:
https://www.amazon.com/3M-03618-Adhesive-Remover-oz/dp/B000BQYA7W
Pinder
  • USA, NJ, Edison
« Reply #7 on: August 30, 2022, 01:38:15 »
i just replaced mine. I just pealed them off and used Eastwood pre clean. You could also just rube it off with goof off or other solvent.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
