Author Topic: Is it time for a new head gasket?  (Read 2093 times)
Nikolaj
  • Denmark, Kobenhavn, Copenhagen
« on: September 02, 2022, 07:57:58 »
Hi all,
I am in doubt if my head gasket is blown. The car has been parked for around 2 years without me driving it.
The engine is running fairly well – I guess there is always something to improve and finetune – but I have noticed that it consumes cooling water and I can smell gasoline when I open the water reservoir (no bubbles) and as you can see from the picture there is leaking cooling water from between head and engine block. I haven’t noticed any other symptoms – compression test is fine, no oil in the water or vice versa.
Is it possible to re-torque the head ? or is it a new head gasket?
Thanks for any good advice.
Nikolaj
WRe
Re: Is it time for a new head gasket?
« Reply #1 on: September 02, 2022, 08:20:18 »
I would try to re-torque the cylinder head first.
Bring the engine up to operating temperature. Slightly loose cylinder head bolts, one at a time, in the sequence shown in the tightening diagram (https://www.sl113.org/wiki/Engine/TorqueHead), starting with 1, and tighten to the specified torque (110 Nm/11 kg/80 ft.lbs).
Good luck!
...WRe
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #2 on: September 02, 2022, 11:09:05 »
..I would try to re-torque the cylinder head first..
I agree with WRe, re-torque the head first. Have you seen any coolant leaking from the reservoir cap (indicating over-pressurization)?
merrill
« Reply #3 on: September 02, 2022, 20:03:55 »
hi
i had similar leaks on my 66.
i tried re torqueing the head,  with the guidance from Joe.
I went as far as to loosen the spark plugs in addition to removing the radiator cap.
but the re torqueing did not work.
purchased a new head gasket from metric along with a can of spray copper sealant, installed the new gasket and have no issues.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #4 on: September 04, 2022, 03:58:05 »
Yes try re-torqueing the head first. It may not always work as merril has indicated, but worth a try.  Don't forget to loosen the radiator cap first to relieve the pressure in the cooling system.
