Author Topic: Windshield aluminum strip  (Read 1297 times)
Michael Foster
  • USA, FL, Doral
« on: September 08, 2022, 13:10:04 »
I have a problem with the windshield aluminum strip.
I had installed the rubber seal on my old windshield and while installing the aluminum strip a managed to crack the old windshield. I got a new one from SLS and have installed the rubber seal and I find that the aluminum strip is a bit too big. The aluminum strip was the right size on the old windshield but now although the rubber fits fine the aluminum strip is about 3/8 inch too long along the bottom. I can just cut off the excess, but I fear that the windshield will not fit correctly.
Any thoughts?
David Robinson
  • Ireland, Connaught, Galway
Re: Windshield aluminum strip
« Reply #1 on: September 08, 2022, 13:39:52 »
Hi Michael
Are you installing the trim on the rubber before you fit the windshield?
https://www.youtube.com/watch?v=vrrpBbZktwI
Michael Foster
  • USA, FL, Doral
« Reply #2 on: September 11, 2022, 16:21:36 »
Yes I did. It seems that the aluminum strip is deformed. when I put it in it moves the rubber away from the corner of the glass and I can see the edge of the glass. I have ordered a new set of strips and we will see what happens. Thanks for the response.
MF
