Author Topic: Lead Additive for Unleaded Gasoline  (Read 6013 times)
« on: May 22, 2003, 14:51:00 »
I purchased my 1969 280 SL several weeks ago.
The previous owner said that I should put "Lead Substitute" into each tank of gas.
Is this actually necessary?
Phil
Re: Lead Additive for Unleaded Gasoline
« Reply #1 on: May 22, 2003, 15:18:44 »
I'm sure others will chime in here but lead substitute is NOT needed with these cars...
Richard M
« Reply #2 on: May 23, 2003, 02:19:46 »
Our local 'GURU' says the same.
The original valve seats are harder than the ones now supplied to convert heads for unleaded.So no additives required.
'Kloines Scheisserle'
LFrank
« Reply #3 on: May 23, 2003, 09:51:04 »
What about other additives? FI cleaners? Marvel Mystery Oil, which some entrust to keep seals in injection system lubed? Any users?
LFrank
Washington DC
65 230 sl
DB334/Hellblau
« Last Edit: May 23, 2003, 11:07:29 by LFrank »
« Reply #4 on: May 23, 2003, 12:18:35 »
I've seen Techron being recommended to clean the injectors (Tom Hanson), but also recommendations against using any additives or cleaners (Achim Ahlert quoting official Daimler-Chrysler info). I don't use any additives and can confirm Naj's statement and can confirm Naj's statement that lead substitutes are not necessary that lead substitutes are not necessary ;-)
Cees
