Author Topic: HELP ON REMOVING RIGHT AXLE / SHOP MANUAL  (Read 1642 times)
toneypenna
  • USA, FL, Jupiter
« on: September 11, 2022, 19:28:19 »
HELLO AGAIN. I LOOKED WITHOUT ANY LUCK IN THE TECH MANUAL FOR INFORMATION ON REMOVING THE RIGHT AXLE ON A 64 230 SL. I FOUND A LOT OF INFO ON THE REAR ASSEMBLY BUT NOT AXLE REMOVAL. I APPEAR TO HAVE A LEAK AT THE BOOT THAT COVERS THE U JOINT ON THAT AXLE. I'M ASSUMING THERE IS ALSO A SEAL UNDER THERE.
ANYONE HAVE ANY EXPERIENCE WITH THIS? I COULD USE SOME DIRECTION.
ALSO I HAVE BEEN LOOKING WITHOUT LUCK FOR A SHOP MANUAL FOR THIS CAR. I'M TOLD THAT HAYNES AND CHILTON HAVE THEM BUT I CAN'T SEEM TO LOCATE ONE FOR A 64 230 SL. I'M ALSO TOLD THERE IS ONE CALLED A BIG BLUE BOOK WHICH I'M ASSUMING IS AN ACTUAL DEALER SHOP MANUAL, DOES ANYONE KNOW WHERE ANY OF  THESE CAN BE ACESSED?
THANK YOU IN ADVANCE FOR ANY HELP YOU CAN GIVE ME.
JIM
BobH
Re: HELP ON REMOVING RIGHT AXLE / SHOP MANUAL
« Reply #1 on: September 11, 2022, 19:44:34 »
There are normally blue book manuals to be found on ebay, i think the 1959 book covers cars up to 1967, but you'd best check
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=Mercedes+Service+Manual+Maintenance+Tuning+Replacement+Passenger+Cars+1959&_sacat=0
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
merrill
« Reply #2 on: September 12, 2022, 14:23:55 »
if you cannot find the paper manual you may still be able to purchase the CD from Mercedes.
I did this job a few years back,   use the search function and you will find what you need.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Essey
  • France, Provence-Alpes-Côte d'Azur, Eze
« Reply #3 on: September 12, 2022, 14:59:30 »
I bought a set of different manuals the other day from: https://mbmanuals.com/series/113/#om
There is a section in the biggest manual on removing and re-installing the rear axle. I have little to 0 mechanical knowledge, but it looks like it provides the necessary info for someone who is capable.
I would happily post it her but i think it is against the rules of the forum. Here are a few pics.
it was only 35$ so worth a shout.
Good luck
Sean
Sean
SL230 W113 1965,
Euro, Automatic,
White exterior
Light Yellow interior
David Robinson
  • Ireland, Connaught, Galway
« Reply #4 on: September 12, 2022, 15:20:43 »
Toney
Is it the boot on the swing axle that is leaking? You can fit the attached without removing the axle.
https://www.sls-hh-shop.de/main/en/mercedes-190sl-w121-/35-rear-suspension/sw-axle-sleeve-open-repair-premium-quality-p-135678
toneypenna
  • USA, FL, Jupiter
« Reply #5 on: September 13, 2022, 16:20:45 »
Thank you for responding
toneypenna
  • USA, FL, Jupiter
« Reply #6 on: September 13, 2022, 16:22:07 »
toneypenna
  • USA, FL, Jupiter
« Reply #7 on: September 13, 2022, 16:26:23 »
Sean
Thank you for the tip
Jim
