Author Topic: Automatic gearshift knob…Q? How to remove?  (Read 1597 times)
Bshaunessy
  • Canada, British Columbia, Invermere
  • 1957 190 SL; 1970 280 SL; 1975 450 SL; 1971 300 SE
« on: September 12, 2022, 01:02:25 »
Help pls.  Trying to remove gear shift knob 1970 280 sl, auto transmission.  Knob won’t thread off.  Is there a trick?
dirkbalter
  • USA, CA, Corona
Re: Automatic gearshift knob…Q? How to remove?
« Reply #1 on: September 12, 2022, 01:35:45 »
It’s not threaded. It’s presses onto the shaft which has ribs or splines. (230, but I believe it’s the same for the 280s)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Bshaunessy
« Reply #2 on: September 12, 2022, 13:53:32 »
Photo and description very helpful thx.   Looks like press on / press off process.   Hope the press off doesn’t ruin the metal flutes as I’m replacing black gear shift knob with a used white knob.
dirkbalter
  • USA, CA, Corona
« Reply #3 on: September 12, 2022, 15:16:13 »
I am replacing the knob too. Not sure where you bought yours but the bore in mine is to small and needs to be opened up a bit in order to press it onto the shaft.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Davek1
  • United Kingdom, England, Wells
« Reply #4 on: September 12, 2022, 18:00:31 »
I recently bought a auto knob from MB, Its a very tight fit. I used a soft rubber hammer as a helper. I did think about opening the hole up but decided against it in the end
