Author Topic: Problem with my membership status  (Read 1553 times)
Tom in seattle
  • USA, WA, Shoreline
« on: September 15, 2022, 16:17:41 »
I am a full member but cannot access the technical manual.  How to fix this?
Tom Averill
1967 250 SL Auto Euro Spec
Re: Problem with my membership status
« Reply #1 on: September 15, 2022, 21:26:32 »
Tom,
You do show up in the name/member note (on the left side of each post) as a full member. So that is the first hurdle.
What do you see or what message do you get if you click on the "Technical Manual" link in the string of items starting with "Home" on the left.
That should take you directly to the technical info and you should be able to just browse through that to your hearts content. We need a bit more information to better understand what might be wrong.
« Reply #2 on: September 16, 2022, 07:31:14 »
Use your browser to clear all cookies for sl113.org.  See here for generic instructions: https://us.norton.com/internetsecurity-how-to-how-to-clear-cookies.html#
Then: go to sl113.org and log in on the forums. Make sure you are logged in. Then click on the "Technical Manual" button in the menu bar...
