Author Topic: Bolt on side of Block  (Read 2624 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« on: September 19, 2022, 18:02:10 »
hello all, can someone please explain the purpose of this bolt on the side of the block? (red arrow in the photo below) Reason I ask, the bolt was missing when I got my block back and I'm not sure what it looks like nor how long it is. thanks in advance, charles
« Last Edit: September 19, 2022, 18:10:04 by Charles 230SL »
Re: Bolt on side of Block
« Reply #1 on: September 19, 2022, 20:51:39 »
Nothing goes there. I don't think the hole is even threaded.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #2 on: September 20, 2022, 00:17:01 »
Oh good grief, I pointed the arrow at the wrong thing! Thanks Joe, do you know what the bolt further below on the chain gallery is for?
« Last Edit: September 20, 2022, 00:46:28 by Charles 230SL »
« Reply #3 on: September 20, 2022, 00:51:22 »
It is a rounded end bolt that helps to keep the chain from jumping off. On a power steering car it also holds the lower steering pump reservoir bracket.  There are two length bolts depending on if it has power steering or not.
« Reply #4 on: September 20, 2022, 04:12:39 »
Pat is exactly correct.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #5 on: September 20, 2022, 12:30:58 »
Pat and Joe - thank you ;) !
As future reference for anyone needing a picture and length of the bolt, here's a link providing additional information: https://www.sl113.org/forums/index.php?topic=27136.
« Last Edit: September 20, 2022, 12:40:44 by Charles 230SL »
