Author Topic: Camshaft Pedestals Alignment  (Read 2640 times)
Runale
  • Malta, L-Iklin, Iklin
« on: October 04, 2022, 13:42:34 »
Hi all,
I have recently renovated a cylinder head from a 250SE engine, my plan is to have this replacement for my 250SL and also in terms of parts investment (seeing that spare parts are constantly increasing in price).
Once pressure tested, faced and the valves full seated,  i came to the point of remounting the pedestals but got stuck on the alignment.  Apart from being bolted on by the main headbolts, all four pedestals have a side mounted nut which somehow could modify the Y -axis of each pedestal
Could anyone let me know the correct procedure and the torque set on these four nuts? or should these just be tightened after the camshaft is slid into place? I read on haynes manual that the pedestals should not be touched, but i had to remove them for the machine shop to work on the head properly.
Thanks for the help
Alessandro
Alessandro
1967 250SL G050 G040
1979 W123 200D
2019 DB11 AMR
MikeSimon
  • USA, OH, North Royalton
Re: Camshaft Pedestals Alignment
« Reply #1 on: October 04, 2022, 14:24:17 »
Other experts may have better suggestions, but I fly by the seat of my pants: After installing the head completely and torquing all bolts down, I do not install the rocker arms and the drive chain sprocket, which enables me to turn the cam by hand. If it turns free and easy, I consider it fine.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: October 05, 2022, 04:26:43 »
Good advice from MikeSimon!
Runale
« Reply #3 on: October 05, 2022, 06:22:13 »
Hi ,
Will try it! Thanks
Alessandro
1979 W123 200D
2019 DB11 AMR
