Author Topic: Ignition Control Box  (Read 1983 times)
Benz280
  • USA, NJ, Jersey City
« on: October 08, 2022, 02:22:38 »
Having an intermittent issue where engine will stall at around 185 degrees.
Wont restart until engine cools a bit. Some research is pointing me to the the electronic ignition box ( 71 280sl ) .
Has anyone experienced any issues at this level ?
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: Ignition Control Box
« Reply #1 on: October 08, 2022, 16:00:58 »
Take a look at the technical manual - Electrical system. Click on that and then look for Ignition System - click that and scroll down to "transistorignition" and read through how that works and what to look for.  This should give you some idea about how this is set up.
I found this thread that may be of interest
https://www.sl113.org/forums/index.php?topic=10721.msg71193#msg71193
You might also want to take a look at the Emission Control System - click on that and it takes you to a description and info. It can also impact running.
Also try the search function . I found the thread above on the first page of search hits. I used "transistor ignition -petronix" without the quote marks, but not the "-" in front of petronix. In a search if you use that minus sign, the search will exclude that term. It gave me three pages of hits.
« Last Edit: October 08, 2022, 16:08:41 by Jonny B »
Benz280
« Reply #2 on: October 14, 2022, 17:38:05 »
Thanks Jonny B,
have gone through linkage and WRD and cant help but feel its an electrical ignition issue given that its as if its getting no spark.
Came across a NOS ignition Box, coil and ballast lets see how that goes.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
« Reply #3 on: October 14, 2022, 23:06:24 »
Thanks Jonny B,
Yes, Jonny's reply was all about helping with ignition.  Did you follow his recommendations?
Thanks Jonny B,
Did troubleshooting and diagnostics lead you to trying a different ignition box, or are you "throwing parts at it"?  Hoping you're going about it smart to save yourself time, money, frustration.
« Reply #4 on: October 15, 2022, 15:43:34 »
Be sure to check the wiring for grounding items. Some of the small connections can be problematic.
Also check to see if a separate wire was added to the electronic control box to allow for easier ability to hook up a dwell meter. If there is a wire and there is a small bare spot grounding out, the car will not start - ask me how I know that one.. ::) ::)
