Author Topic: Steering box, cover, sequence of parts "rings # 27 on drawing"  (Read 1798 times)
BartSt
  • Belgium, Flanders, Antwerp
All,
Hope all is well.
I need some guidance of how to re-assemble the bottom of my Steering servo.
Pls have a look at the drawing, and then the 2 photos with the options.
Is it photo A or photo B?
« Last Edit: October 21, 2022, 14:55:52 by BartSt »
Re: Steering box, cover, sequence of parts "rings # 27 on drawing"
« Reply #1 on: October 21, 2022, 20:28:41 »
I've never taken this stuff apart, but to help others, please state if the three parts of the assembly are:
- layed out in the same sequence, but flipped over
- layed out in a different sequence, but also flipped over
Also, is your housing(?) oriented the same as in the exploded parts diagram, or is it flipped?
BartSt
« Reply #2 on: October 22, 2022, 09:27:51 »
Dear Rod,
Thanks for taking the effort in writing a reply.
My main question is about the sequence of the 2 shown parts, radial shaft seal and the seal ring.
My seal ring is solid steel, with a blue rubber inner lining.
If I lay under the car, I first detach the cover of the steering box, and in the cover I have the 3 rings (including the lock ring)
Now I want to know if:
1. I first install the radial shaft seal, then the seal ring and then the lock ring
2. What size is "up" for the seal ring? With the blue part on the outside or the steel edge on the outside? (see pict)
I hope this explanation is understandable
Be well,
Bart
DavidAPease
  • USA, CA, Chico
« Reply #3 on: October 23, 2022, 01:49:22 »
Hi, Bart,
I'm not sure which car you have, but this close-up diagram of your parts is from my 230SL parts manual.  It clearly shows the order in your photo B (as in, Bottom photo).  The description of item 83 is Radial Seal Ring; 84 is Supporting Ring; 85 is Lock Ring.
It also seems to show the Supporting Ring with the lip pointed "up", that is into the Seal Ring (the opposite direction from your photo); that makes sense, as there would be no reason to have a lip towards the Lock Ring.
I'm not sure if this answers all of your questions, but I hope it helps.
-David Pease
BartSt
« Reply #4 on: October 23, 2022, 09:11:20 »
David,
Many thanks for the high res picture.
Now it is much more clear.
Be well,
Bart
BartSt
« Reply #5 on: October 23, 2022, 15:55:02 »
David,
Problem solved!
Thanks again.
Bart
