Author Topic: Temperature gauge  (Read 2152 times)
Michael Foster
  • USA, FL, Doral
Temperature gauge
« on: October 21, 2022, 15:04:19 »
My temperature gauge capillary tube will not fit into the hole between No. 5 and No. 6 spark plug. There seems to be something blocking it from going all the way in. is there a 14 mm extension/adapter I could use? I have tried to adapt some fittings I have, but they do not have a lip/stop to hold the capillary tube against the nut.
1970 280 SL automatic
dirkbalter
  • USA, CA, Corona
Re: Temperature gauge
« Reply #1 on: October 21, 2022, 16:00:01 »
Is it a new one or are you trying to reinstall the old one?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Michael Foster
  • USA, FL, Doral
« Reply #2 on: October 21, 2022, 18:10:36 »
Trying to install the old one.
MF
dirkbalter
  • USA, CA, Corona
« Reply #3 on: October 21, 2022, 21:39:04 »
MF
In that case I am no help. I bought a new one (SLS) and this needed some grinding on the OD to fit properly.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
ejboyd5
  • Southold, NY
« Reply #4 on: October 22, 2022, 11:59:27 »
If it came out, it should go back in unless something broke off and is blocking the thread.  How long has it been disassembled? Post picture of the capillary tube end and of the area where it is suppose to fit.
Michael Foster
  • USA, FL, Doral
« Reply #5 on: October 23, 2022, 14:26:27 »
Thanks for the help.
I have a newly rebuilt engine from Metric.
What I need is a 14mm, 1.5 male x 14mm, 1.5 female adapter. Seen photo
I have seen one in a photo of the cool kit that Bud´s Benz has and I am talking to David to see what I can get.
MF
« Reply #6 on: October 24, 2022, 23:31:37 »
Those are standard on most Mercedes heads of the era. Should be easy to find used or new from MB if you get the part number?
Michael Foster
  • USA, FL, Doral
« Reply #7 on: October 27, 2022, 11:08:13 »
thank you all for your help. I had searched every where including Amazon without any luck. I searched again and now Amazon has them, I bought 2 of them.
MF
