Author Topic: shifter linkage, attachment of stabilizing rods at shifter end, 280 SL  (Read 2130 times)
pauloe
  • Canada, British Columbia, Salt Spring Island
I have disassembled shifter linkage.  Ordered all bushings.  One question on reassembly.  Catalog B diagram shows no washers on the connections, below the plate 85 or above the plate under nut 111.  But many pictures I see here show a washer under nut 111.  (plate 85 is numbered 264 and nut 111 is numbered 310 in https://www.sl113.org/wiki/TransmissionClutch/Shifter).  The bushings 86 (268 in wiki) were missing and replaced by a length of rubber tubing when I disassembled, so I didn't see what it is supposed to look like.  any help would be appreciated so I can put this back together correctly.
Paul
1969 280SL 4 speed 050 white 040 black
