Please check out joining the
Emergency Contact List
for help during your travels!
E10 fuel lines
Topic: E10 fuel lines (Read 1715 times)
markatspace
Associate Member
Junior Level
United Kingdom, England, Crewe
E10 fuel lines
October 31, 2022, 11:23:55 »
Just adverted a major disaster with a leaky fuel line in the engine bay. My flexible fuel hoses have degraded and a split was spraying fuel onto the engine. I understand there are issues with the ethanol in the fuel. My problem could be a combo of old perished lines and ethanol? But they now need replacing. Does anyone have a solution for using a E10 compatible fuel line?
Paul & Dolly
Full Member
Gold
United Kingdom, Wales, CARDIFF
i Car
Re: E10 fuel lines
October 31, 2022, 16:01:53 »
I use Esso supreme. + ,99 which is marked 5% ethanol but can actually have no ethanol in certain parts of UK, just Google. Esso synergy fuels.
E10 Comparable fiel hose is available on eBay.
Keep safe
Paul
1967 Early 250 SL (Auto) White
Mitsubishi i Car
Toyota RAV 4 Hybrid AWD
Associate Member
Platinum
Canada, ON, Port Lambton
Re: E10 fuel lines
Reply #2 on:
October 31, 2022, 21:37:02 »
I keep hearing about this but have not seen any problems so far. Fuel hoses fail over time regardless of what fuel you use. The rubber impregnated cotton hoses that MB uses are not that great to begin with.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
E10 fuel lines
