Author Topic: rpm 'wanders'  (Read 3452 times)
toml
rpm 'wanders'
« on: June 13, 2005, 20:05:14 »
Hi Kids.
What can be the cause of a wandering idle. The motor has got 25k on a total metric rebuild and the fuel system was recently purged. There is the tiniest drip of oil coming from somewhere in the fuel injection pump (the gasket at the firewall-end of it seems a tiny bit wet), though I have no idea if that is related.
My guess would be something like air/vacuum leak? But I'm not sure. On ocasion it would drop low enough to conk out.
What could be the cause?
Thanks.
TomL, Portland, OR
1964 230SL Euro 4-speed Silver+Black w/ Red Interior
1973 280C DOHC Metalic Blue w/ Tan interior
Re: rpm 'wanders'
« Reply #1 on: June 13, 2005, 20:33:08 »
For starters, Check CSV for leak-by and check vac line to booster for leaks..
« Last Edit: June 13, 2005, 21:07:10 by A Dalton »
Re: rpm 'wanders'
« Reply #2 on: June 13, 2005, 21:50:15 »
Hello Tom,
Lots of tuning possibilities. Check the points first. Especially the non transistorized ignition cars like your 230SL.
