Author Topic: Fuel filter housing  (Read 1830 times)
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
Fuel filter housing
« on: November 28, 2022, 23:57:30 »
The attached picture showing the top of the fuel filter holder. There are two bolts and I wanted to know what they do.
The large one will not unscrew. I have not tried holding it in a vise. I am worried about breaking the part while trying to unscrew the bolt.
I was able to unscrew the small one and the seal needs to be replaced. Where can I find a replace seal?
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
Re: Fuel filter housing
« Reply #1 on: November 29, 2022, 01:54:22 »
The small one is an air bleed which usually not needed. It just uses a copper seal ring.
It has been many years since I disassembled this unit but pretty sure the large bolt is a plug. Correct me if I wrong though. I don't believe it has a seal since it is not supposed to be removed. I did remove mine and just used a thread sealant when it was reinstalled. I took the plug off to be plated.
MikeSimon
  • USA, OH, North Royalton
« Reply #2 on: November 29, 2022, 12:54:14 »
Sometimes, holes are drilled into cast parts that are needed for machining internal passages. They are then plugged.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
jim 56
  • USA, NY, Bellerose
« Reply #3 on: December 22, 2022, 12:35:28 »
I put a pressure gauge in where the large screw is and it helps me troubleshoot fuel related problems
