Author Topic: Metric Screw 1964 230SL Rearview Mirror  (Read 1226 times)
JimEast
  • USA, AR, Little Rock
« on: November 30, 2022, 16:55:32 »
Does anyone know the size for the screw? Thanks!
-Jim
Re: Metric Screw 1964 230SL Rearview Mirror
« Reply #1 on: November 30, 2022, 17:43:19 »
Are you asking about the screws to attache the base plate to the window frame?
For the base plate - the parts book shows - three required -  DIN 007982 004206 (B 4, 2X22 DIN 7982 DBL 8454) DIN 7982 = Sheet metal screw,  4.2 X 22 mm DBL 8454 - finish of galvanic chromium plated
I was not able to find the meaning of the "B" in the DIN part listing - it appeared to be used for sheet metal screws, not machine type screws which would have "M" for metric. I am sure others will be able to decode that.
