Author Topic: Entrance Lighting  (Read 3760 times)
Entrance Lighting
« on: November 30, 2022, 19:29:34 »
I know many people don't drive their Pagodas at night, but I'm curious if anyone has done anything to upgrade their entrance lighting?  That single dim bulb under the center dash area isn't much.  Anyone hook up something more substantial?  I like how my 450SL has a pair of lights in the windshield header, between the glass and sun visors.  (Although, those are low voltage dim lights as well.)  Maybe a small wire could be run up the A-Pillars and a small bulb placed in the corners, maybe even using adhesive on the glass?
Re: Entrance Lighting
« Reply #1 on: November 30, 2022, 19:34:05 »
Maybe something like this?
https://www.oznium.com/led-bolts-prewired-leds/prewired-surface-mount-led
I assume it would be easy to connect into the door switch circuit, since the interior light already does that.  Right??
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
« Reply #2 on: November 30, 2022, 19:59:42 »
Hey rwmastel,
I also found the lighting to be way too dim, so I upgraded the bulb inside the cabin light to an LED version (not an easy fit, but just about got it in there at an angle!), and I also used some adhesive-backed LED strip lighting which I ran along the bottom of my Budz Benz aftermarket aircon unit, which I wired into the cabin light terminals. I think I got the inspiration from another member of this forum but I would have to dig out the post.
The results have been pretty good (although the adhesive on the LED strip does sometimes come undone).
Photos attached
1971 280SL auto #571 over parchment
Jack the Knife
  • USA, FL, Vero Beach
« Reply #3 on: December 02, 2022, 18:24:21 »
That looks really excellent!
1964 230SL "Blue Note"
2015 G550 "Milk Truck"
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #4 on: December 02, 2022, 21:24:55 »
There are lights when you open the door?   I need to find mine and get them working.  That looks great.
The things I learn on this forum...
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
« Reply #5 on: December 03, 2022, 01:58:15 »
One light.  Under middle dash.
https://www.sl113.org/forums/index.php?topic=17305.msg119982#msg119982
alpina
  • Spain, Asturias, Villaviciosa
Rahul
« Reply #7 on: December 03, 2022, 15:29:52 »
There it is! Thanks alpina, great solution and still working well today
« Reply #8 on: December 03, 2022, 23:40:47 »
Yes.  Very nice AlpinaLTD.
