Howdy gents,
I set about removing the old Eclipse CD player the first owner added to my SL. That was quite a bit of wrangling, as it appears the guy who evidently cut the opening was drunk. The opening can accommodate a Becker Europa. I have a unit sitting in my living room converted over to the Aurora guts by Bill the Radio Guy over in Washington. My car was originally optioned without a radio. I'd appreciate everyone's advice here:
Would you keep the radio opening size as-is and install the Becker I have in-hand?
Or would you purchase an unmolested 230SL mounting plate (seems these are relatively inexpensive at $89 from Authentic Classics) and install the correctly-sized radio?
Or install no radio at all, as that was how the car was delivered I suppose, and instead opt for a fine JBL Bluetooth speaker setup throughout the car?
Just as well, it appears the first owner for some reason decided to drill two holes in the glove box door... also at a slight angle... and mount the radio delete plate there. I have removed that plate, though I now have two holes in my glove box door. Seems I can acquire a glove box door for around $150-$200 and refinish/repaint it. Unless there is a better option with the existing door?
As always, I appreciate the great advice on this forum. See attached for a photo of everything before I took it all apart.
