Author Topic: RUBBER seals/trim for windows and doors  (Read 4062 times)
duke
  • USA, IN, Indianapolis
« on: December 27, 2022, 15:37:38 »
I have a 64 230 SL.  I need rubber seals/trim for all of the doors and windows.
Any ideals where to get these items?
Lorsar
  • Membership Administrator
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: RUBBER seals/trim for windows and doors
« Reply #1 on: December 27, 2022, 16:00:52 »
I got most from the classic center. Reasonable prices  except the ones that go around the door. The MB price was $500 each.  I opted to get the Uro repros from Autohausaz.com for $40 each
Lori
1968 280SL (US)
dirkbalter
  • USA, CA, Corona
« Reply #2 on: December 27, 2022, 16:06:11 »
Due to the high price of the OEM, I bought most of it from SLS . I doubt that these are much different. Seals fit well.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #4 on: December 28, 2022, 18:22:52 »
Be aware that if you replace the front window seals on the hardtop with aftermarket ones, you may encounter problems rolling up the window.  The OEM channels have fabric embedded that allow the glass to slide up.  Some of the aftermarket ones are just rubber and will bind and snag.  I learned that the hard way.  Seals for the permanent windows should be fine.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: December 28, 2022, 19:41:56 »
Raymond,
Are these the ones you are talking about?
They have material embedded into the rubber. (SLS).
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
