Author Topic: Which oil in ZF  (Read 1925 times)
mazmonza
  • United Kingdom, England, Lydeway Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Which oil in ZF
« on: January 27, 2023, 12:24:26 »
Which oil do any members use in their ZF 5 speed gearbox ?
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
Re: Which oil in ZF
« Reply #1 on: January 27, 2023, 16:03:51 »
I use synthetic ATF in mine.
Atazman
  • USA, Ca, Pleasanton
Re: Which oil in ZF
« Reply #2 on: January 27, 2023, 18:44:38 »
Pennzoil ATF (GM and Mercon)
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
mazmonza
Re: Which oil in ZF
« Reply #3 on: January 28, 2023, 09:35:49 »
Does it have to be Dexron 2
2000 Ducati 748s
1970 Ducati Monza
Re: Which oil in ZF
« Reply #4 on: January 28, 2023, 15:47:52 »
Not sure about that but it should be red.  :)
MikeSimon
  • USA, OH, North Royalton
Re: Which oil in ZF
« Reply #5 on: January 28, 2023, 18:13:27 »
Some ATFs are green....
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: Which oil in ZF
« Reply #6 on: January 28, 2023, 18:27:51 »
Yes, and some are blue for hydrac transmissions but most modern ATF is red. Any ATF should work, but a ZF 5 speed is an extremely rare and valuable unit which really doesn't hold a lot of lubricant, so I use the best I can find which is a synthetic.
mazmonza
Re: Which oil in ZF
« Reply #7 on: January 28, 2023, 18:42:16 »
Are you willing to say which one?
2000 Ducati 748s
1970 Ducati Monza
Re: Which oil in ZF
« Reply #8 on: January 28, 2023, 18:53:11 »
Sure. AMSOIL, Quaker State, Royal Purple, etc.  Most are expensive but you only need about two liters so it's not a big thing. I also use synthetic lubes in the entire car. Engine, transmission, rear axle, power steering, grease. Lubes are pretty cheap compared to engine rebuilds or any other part of your car.
mazmonza
Re: Which oil in ZF
« Reply #9 on: January 29, 2023, 09:15:10 »
Thank you for that
2000 Ducati 748s
1970 Ducati Monza
