[quote author=Jack the Knife
lGarbage only useful for a purist to feel good about his 1965 insulation, who probably doesn't drive his car anyway so it doesn't matter.
Unquote
Thats a bit of a throwaway line Jack
90% of members would be in the purist category but they do drive their cars. 🤐
Throwaway is right, because the real punchline is that
I don't even drive my car.
... by the way, the other 4 Pagodas here in town all have antique plates. That says it all...
Here is another one for your R & D project, I used that one.
Thanks Dirk. Looks like this stuff one might achieve a 4db reduction. I'd be careful using it over the firewall or especially the exhaust since it seems to be prone to melting. As we know, weight has a lot to do with noise/vibration reduction. Each square foot of Xmat weighs 12.8oz, or .8lbs and is 62.5 mils thick. To compare with the competition:
3M EDM -- 0.22lbs (also the least effective... without mass and/or numerous layers of things, you won't get any results)
Resonix CLD -- 1lb
Dynamat Xtreme: 0.45lbs
Kilmat -- 0.35lbs or 0.5lbs
Fatmat -- 0.46lbs
And as for thicknesses of the above, which are all butyl based, btw:
3M EDM -- 62 mils
Resonix CLD -- 104 mils
Dynamat Xtreme -- 67 mils
Kilmat -- 50 mils or 80 mils
Fatmat -- 80 mils
If I had to hazard a guess, it is going to be better than the 3M product (though people buy that for weight) and probably as good or better than Dynamat and Kilmat.
