Author Topic: parts wanted heater blower housing  (Read 4039 times)
maxabw
  • USA, NC, Chapel Hill
« on: January 30, 2023, 17:22:48 »
need blower motor  mounting bracket1968 280sl
« Last Edit: January 31, 2023, 19:32:44 by maxabw »
m300cab
  • USA, Pennington New Jersey
Re: parts wanted heater blower housing
« Reply #1 on: February 01, 2023, 21:28:27 »
find it yet?
Michael Parlato
« Reply #2 on: February 01, 2023, 22:53:54 »
I have a complete assembly.
Leester
  • USA, VA, Lorton
« Reply #3 on: February 02, 2023, 01:54:52 »
If I recall the at the bottom of the heater box there is a rubber buffer (like the two at the top) with M6 threads. I think it fastened to the bottom of the heater box at the center then attached to the small bracket you are missing. I too did not have that bracket so I fabricated one. I think it was just about an inch by 2 inches and maybe a 90 degree bend in middle. It has to have a hole in it for the M6 thread of the rubber buffer to fit into. Again, its been a while back but I think the bracket is fastened to the transmission hump maybe with an M6 screw and nut. You may have to do trial and error to get the angle of the bracket right. Its a bit of pain since there is almost no working room. Hope this helps. Lee
Lee Backus
1963 220SE Cabriolet
1985 500SEC
