Author Topic: Fixing the indicator stalk left indicator cancel  (Read 12288 times)
Pinder
  • USA, NJ, Edison
« on: February 01, 2023, 02:59:30 »
I have an issue with the left indicator cancel caused by earlier repair. The root cause is a stripped thread on one of the two special screws that hold the Stalk to the gizmo that rotates in the housing. Sorry if I am not using the correct part names but this post is to upload pics of the mechanism for anyone else who wants to attempt a repair.
« Last Edit: February 01, 2023, 03:33:10 by Pinder »
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder
  • USA, NJ, Edison
Re: Fix the indicator stalk left indicator cancel
« Reply #1 on: February 01, 2023, 03:06:10 »
This pic is of my strip thread repair attempt 2 using jbweld . Applied to the screw then held in place with vice grip. Also clamped down on the alloy part so the gap of the slot where the stalk insert is now redused. I think over time this soft metal gets wider
Re: Fixing the indicator stalk left indicator cancel
« Reply #2 on: February 01, 2023, 14:08:09 »
I have a box of left over parts from repairs I have done on these in the past. I probably have that part good used, if your repair fails. Also some sedans of the era used a turn signal stalk assembly with most of the parts the same (65-67 finbacks). They're not the same but most of the parts are.
dirkbalter
  • USA, CA, Corona
« Reply #3 on: February 01, 2023, 15:39:05 »
There are a pretty good instructions on the web-side from our German speaking colleagues on how to repair these.
https://www.pagodentreff.de/diskussionsforum/
(If you have trouble navigating and interested, let me know and i send it to you.)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Pinder
  • USA, NJ, Edison
« Reply #4 on: February 01, 2023, 17:50:21 »
Thank you Joe and Dirk for responding.
The JB weld did not hold too long.  So I am going to use a larger screw and see if that fix works better. If it does not I will reach out to you Joe if you have the metal part to which the indicator stalk attaches with the two screws.
Regards
   Pinder
« Reply #5 on: February 01, 2023, 18:23:19 »
Group,
I remember asking many years ago about fixing the return feature on my 230SL signal stalk and being told that it is best to buy a replacement unit.  I never fixed or replaced it.  I would be very interested to learn more about what's worn in my assembly that causes the problem and how to fix it.  It seems like an assembly that can be understood by any of us mechanically minded people, even me!   ;)  Is removing the assembly from the column a straight forward (simple) process to figure out?
Hi Joe,
I would be interested in learning if you have any pieces that would help me fix my assembly.  Does having the flash-to-pass feature make things significantly more complicated?  I'll get it removed and apart, this weekend if I'm lucky, and then get back with you.
BobH
« Reply #6 on: February 01, 2023, 18:37:48 »
There's a good write up in the tech manual about removing the switch and common problems
https://www.sl113.org/wiki/Electrical/SteeringColumnSwitch
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #7 on: February 01, 2023, 18:45:58 »
Sorry, got excited about an interesting post with pics and quickly replied without searching. Not following my own normal advice!!  Thank.
dirkbalter
  • USA, CA, Corona
« Reply #8 on: February 01, 2023, 19:11:23 »
Here you go. You will need a little google translate.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Pinder
  • USA, NJ, Edison
« Reply #9 on: February 02, 2023, 00:02:26 »
Ok I was able to fix the issue with the loose screw by using a larger screw and grinding down the end of it so it fits the small hole in the stalk. This along with clamping the component that holds the stalk so that the loose fit is now gone (I suspect that as its a soft alloy it bends over time and use. It was a little difficult to get it all put back together but its done. I just need to install it back in the car. it appears to work find with the plastic canceling tab sticking out when turning left or right.  Main cause of failure was the loose screw and the jaws of the component that accepts the stalk being wider at the ends. I fixed both issues and it seems so much less play and appears to work as I would expect. I will install it tomorrow and report back on if it worked.
« Last Edit: February 02, 2023, 00:47:39 by Pinder »
Pinder
  • USA, NJ, Edison
« Reply #10 on: February 02, 2023, 00:04:41 »
Picture of the jaws and the new larger screw installed solidly.
Pinder
  • USA, NJ, Edison
« Reply #11 on: February 02, 2023, 00:10:49 »
The post by Dirk is very good. It highlights all the trouble spots. But for me I had two issues. Loose/ striped screw and the widened gap the stalk end fits into.
Pinder
  • USA, NJ, Edison
« Reply #12 on: February 02, 2023, 00:18:13 »
Removing the stalk from car is relatively straight forward. (this is for my 280SL 1970)
steps are as follows.
1. Remove the under dash trim ( that is covered with vinyl in my case just to the left of the steering wheel.
2. pop of the rubber boot on end of the stalk on the steering column.
3. remove two Philips head screws that hold the stalk to the column.
4. remove the black and brown wire for the horn that attaches to the stalk base.
5. disconnect the 12 pin plug from under the dash that connects to wiring harness.
6. remove the rubber Gromet that is on on the steering column where the wires go into the steering column. It has a slit on one part so it can be removes.
7. slowly pull out the stalk brining the wiring with it and fiddle the plug end into the steer column hole. It is just small enough to be able to be removed without disassembly.
« Last Edit: February 02, 2023, 02:22:23 by Pinder »
Pinder
  • USA, NJ, Edison
« Reply #13 on: February 02, 2023, 00:27:45 »
   If you disassemble just do it in good lighting and preferably wear some eye glasses (to protect your eyes from springs that tend to become projectiles) and keep track of the parts. Take lots of pictures so you know how the springs go back in.  Parts fly around. I lost the washer under the C clip and at one point lost the C clip and found it 1 hour later.  I was lucky that the black plastic cancelling cam had no wear on mine but I can see this could be an area that may wear out and prevent cancelling. Also in my case I had done an earlier repair using JB weld on the screw I now fixed properly. The JB weld failed and the fragments were interfering with the cancel of the indicator. there was also a lot of dirt and dust in the unit. Taking apart and cleaning everything should help my situation. Ill find out how well it works and will update.
from doing the disassembly and if parts available or can be repaired this is definitely a switch that can be fixed.
Regards
  Pinder
« Last Edit: February 02, 2023, 02:24:47 by Pinder »
Pinder
  • USA, NJ, Edison
« Reply #14 on: February 02, 2023, 19:06:12 »
Confirmed after install that the indicator stalk now works cancelling left or right automatically. All other functions like wipers and washer work.
Pinder
  • USA, NJ, Edison
« Reply #15 on: February 11, 2023, 01:40:05 »
So on a recent test drive and taking notice on how the "fixed" indicator stalk works I find the cancel operation works every time and as expected. However I note that some time when I indicate left the leaver springs back up and i have to make sure i push it on purpose down all the way to hold.  THis could be wear on the cam but I did not note any wear. Or could it be i have the return springs the wrong way round. I think maybe one return spring is stronger than the other and I put them back wrong positions? my guess is that one spring should be weaker and one stronger due to gravity being factorered in?
Any thoughts on this. or am I barking up the wrong tree?
Regards
  Pinder
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #16 on: February 11, 2023, 07:53:49 »
Regards
  Pinder
you have not repaired main issue on this stalks which is causing problem you have. Im sorry for my bad english.. see attached pictures. "swing arms" must be attached correctly using special screws. Even when their riveted base is not broken they have too much play. Cylinders on top must have perfect 90 degrees angle... Some other modyfication must be done too...
Every single indicator stalk have this issue and must be correctly fixed. Forget about reproduction stalks, they are piece of junk. I do repair on these for 250,-€ or you can buy new one from me for 550,-€ and send over your original untouched non working to me
regards
1964 230SL
yves
  • France, Poitou-Charentes
« Reply #17 on: February 11, 2023, 12:14:27 »
Here some pics of the problem with the spring arms :
and an extension of the pin with a drop of bondic .... if it's needed ?
Pinder
  • USA, NJ, Edison
« Reply #18 on: February 11, 2023, 20:11:52 »
Yves thanks for the post and explanation. And yes the pins do bow out a bit and I did think maybe they should be 90 degrees. With my bad eyesight i did not notice the screws were type of hex screw. I can give it a go and fix that. Im getting pretty good at removing the indicator from the car now.
  I appreciate the response.
 Regards
   Pinder
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
« Reply #19 on: February 12, 2023, 00:07:31 »
If I recall correctly, a recommended fix for the bowed pins was to drill them out, tap the holes to accept an M3 or M4 screw, and to then dremel off the heads of the screws to leave just the posts.
Yves, it may very well have been your posts that covered this, the photos look familiar!
1971 280SL auto #571 over parchment
yves
« Reply #20 on: February 12, 2023, 09:34:38 »
You are right Rahul  ;)
yves
« Reply #21 on: February 12, 2023, 09:47:23 »
Here is the link about my work on the indicator:
https://www.sl113.org/forums/index.php?topic=30504.msg242586#msg242586
Pinder
  • USA, NJ, Edison
« Reply #22 on: February 13, 2023, 22:04:57 »
Ok I have an update. on fixing the indicator so it holds in the down position.
I open the switch and corrected the condition where the rollers were a bit loose where the rivets mount to the alloy body of the switch. I didnt have any special screws to re tap and fix but I was able to get rid of the non parallel roller problem by using a dot punch to firmly fix the rollers. Yves suggested this is the problem. I also did as Joe had mentioned to cleanup the valleys in the indicator cam. I re assembled and tested it out and it works fine now.
thanks for everyone's input in getting my switch working like new.
in my car i was able to remove the switch without taking off the end of the plug. However fitting it back in I had to take the cap of the plug off but I know in the past I have done it without take the cap off.
Regards
Pinder
« Last Edit: February 13, 2023, 22:58:24 by Pinder »
Pinder
  • USA, NJ, Edison
« Reply #23 on: February 16, 2023, 04:08:39 »
Well,
 Any time is a good time for a test drive and an extensive test on the "Stalk". I'm happy to report that all functions works as expected, down position for left, Up for right, Washer fluid squirty thing , wipers and both speeds, auto cancel..... except nothing happens if I pull the stick towards me. I thought it is supposed to trigger high beam? or maybe not?  I do have a button next to my clutch pedal that does high beam and a blue light. But should the stalk [pulled towards the driver] engage high beam? I think it should but don't know. 1970 280SL.
on the plus side I was not distracted with indicator cancelling and it worked well and I could focus on appreciating how well the car is driving. Its not perfect but not bad at all for a 50+ year old car. Few kinks to iron out but really appreciated how well it drives. (but never having driven a new one its hard to really judge)
Regards
 Pinder
« Reply #24 on: February 16, 2023, 04:56:07 »
I have "flash to pass" on my Italian 230SL.  Search for that or similar terms and see if any threads discuss the years and markets that had it.
