Author Topic: Possibly good deal on Ebay for somebody!  (Read 6102 times)
« on: February 06, 2023, 16:54:09 »
I saw this on Ebay. Most parts are the same as on Pagoda. If your lucky the TTS and the Fuel sender is good! The seller offered it all to me for a lower price of $59.00   I do not need these but I am sure someone out there does!
https://www.ebay.com/itm/155374934101
Joe
Pinder
  • USA, NJ, Edison
Re: Possibly good deal on Ebay for somebody!
« Reply #1 on: February 07, 2023, 00:57:51 »
that is a great price. just for the washer fluid bottler and fuel sender.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder
  • USA, NJ, Edison
« Reply #2 on: March 24, 2023, 22:14:37 »
Just an update. I did buy these parts.  I just wanted a few spares. Mosty I wanted the fuel sending unit. I took it apart and Luckly the thin wires were intact and after a good cleaning it should work fine. the washer bottle was also in good shape.
« Reply #3 on: March 25, 2023, 04:21:42 »
Your already ahead. Did you get a chance to check the TTS ?
Pinder
  • USA, NJ, Edison
« Reply #4 on: March 25, 2023, 11:55:56 »
Joe What's the TTS? I can check if its any good.
Pinder
  • USA, NJ, Edison
« Reply #5 on: March 25, 2023, 12:12:12 »
Joe
Ok so I just went and looked at the block of metal that has the Thermo time switch. I didnt realize it had it on there. I will check to see if it works. it looks intact but will do some testing.
Regards
Pinder
« Reply #6 on: March 25, 2023, 15:25:27 »
Be careful with it. They are very expensive new these days if you can find one. It's probably worth at least $200 used.
Pinder
  • USA, NJ, Edison
« Reply #7 on: March 25, 2023, 15:37:50 »
i will soak it in some penetrant spray and gently remove it.
Pinder
  • USA, NJ, Edison
« Reply #8 on: March 25, 2023, 16:16:37 »
I was able to remove it easily and it cleaned up nice. Will test it out see if it actually works.
Regards
Pinder
Pinder
  • USA, NJ, Edison
« Reply #9 on: March 25, 2023, 17:20:56 »
Using the specs in the tech manual for resistance valves between >35Degrees and < 35 degrees it does check out OK.
Pinder
  • USA, NJ, Edison
« Reply #10 on: March 25, 2023, 18:20:29 »
The housing also had this second switch which I think is a thermo switch . See picture. But it looks longer than other ones I have seen in the tech manual and eBay.
BobH
« Reply #11 on: March 25, 2023, 19:14:40 »
Hello, isn't this the sensor that connects to the temperature gauge capillary tube?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Pinder
  • USA, NJ, Edison
« Reply #12 on: March 25, 2023, 21:20:15 »
Could be Bob. I think it maybe a temp sensor.
« Reply #13 on: March 26, 2023, 05:25:08 »
That is the bulb for the engine temperature gauge. It probably has been cut and now is useless. No big loss, seems you are way ahead at this point!
Pinder
  • USA, NJ, Edison
« Reply #14 on: March 26, 2023, 10:52:03 »
Yes it’s been cut .
Regards
Pinder
