Author Topic: 1966 Rear End Removal  (Read 1667 times)
Harry
  • USA, TN, Knoxville
« on: February 15, 2023, 00:14:57 »
Hello all.  I am about to embark on replacing the klunk bushing in the rear end and I’ve been reading through the BBB on how to do that.  I have a couple of related questions:
- Does anyone have a schematic and/or photo of the fixture used to brace the rear end so the axles remain horizontal?
- I have a lift that I would like to use but I’m a little concerned that with the rear end removed, the car will be nose heavy and prone to tip?
Thanks in advance,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: 1966 Rear End Removal
« Reply #1 on: February 15, 2023, 06:46:36 »
... but I’m a little concerned that with the rear end removed, the car will be nose heavy and prone to tip?
Sand bags (or kitty litter) in the trunk?  It's further back than the axle, so you don't need equivalent weight.  Not sure how much weight a non-rusty trunk should hold.
« Reply #2 on: February 15, 2023, 08:56:04 »
I've removed plenty of axles without worrying about weight distribution. These cars are heavy!
Klaus Pieper
  • South Africa, KwaZulu-Natal, Westville
« Reply #3 on: February 15, 2023, 11:01:00 »
To stabilize the rear axle in a horizontal position, I made a tool out of a length of 1350mm square tubing (38x38mm) and drilled two 18mm holes, 1235mm from the middle of the holes apart.  Use the bottom shock absorber mounting, when the shock absorbers have been removed, to anchor the square tubing.
Harry
« Reply #4 on: February 26, 2023, 19:26:25 »
Thanks for the feedback.  And just to confirm before I pull the rear end, it does have to come out to do this properly - correct?  I'll look in the BBB to see what might be there as well.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Harry
« Reply #5 on: February 26, 2023, 21:34:41 »
And, does anyone have a drawing of the crown nut tool that is necessary to untighten/tighten the pinion nut?  Or even a tool that they would lend?
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
dirkbalter
  • USA, CA, Corona
« Reply #6 on: February 26, 2023, 23:00:13 »
Harry,
See below.
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/25-26-clutch-4-speed-box/26-a-gearbox-manual-/set-3-pcs-tools-fitting-mb-grooved-nut-p-5705
That’s what they look like. I made one myself out of a regular socket and a right angle grinder.
You can take the required dimensions from the nut itself. Mine is with a friend at the moment.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
