Author Topic: Fuel Pump Shroud cover drawing  (Read 4942 times)
ryan.mb
  • Latvia, Riga, Riga
« on: February 21, 2023, 11:42:50 »
Hello W113 community,
I’m doing a full restoration on my 250SL and trying to make from scratch some missing metal parts. Does anyone have Fuel Pump Shroud cover drawing/ blueprint and would be willing to share that?
Cheers,
Raivo
Ryan
1967 W113 250SL
1984 R107 500SL
1990 R129 500SL
DaveB
Re: Fuel Pump Shroud cover drawing
« Reply #1 on: February 21, 2023, 13:15:32 »
I think they're configured differently depending on which fuel pump you have, the early tall version or the later short. If you post a photo of your fuel pump we can let you know.
DaveB
'65 US 230sl 4-speed, DB190
« Reply #2 on: February 21, 2023, 13:27:37 »
The more difficult part will be the rounded-off bottom. The rest should be fairly straightforward.
For the restoration of my '61 Alfa Romeo I just bought a small English wheel, and a bead roller, as that car will need various more complex metalpieces to be fabricated.
« Reply #3 on: February 21, 2023, 17:43:53 »
... trying to make from scratch some missing metal parts ...
Raivo,
Hi.  Why recreate?  Enjoy a personal challenge?  Parts sourcing a big challenge in Latvia?  Perhaps member from eastern Europe (Pawel66 maybe?) can send you a new or used one from Poland?
(I had a Latvian history professor in college, an interesting character with lots of stories.  I also had a Russian geography professor.  She and her military husband escaped during the cold war (1970's).  Also, lots of great stories.)
ryan.mb
« Reply #4 on: February 21, 2023, 19:31:25 »
Thank you, guys, for your feedback. Personal challenge is kind a built in to the restoration process by default, however this process brings a lot of joy and excitement 😊
This particular part is quite easy to recreate, I have all equipment for it, as long as I would have a drawing.
@DaveB a fuel pump on my SL is short version.
Ryan
1967 W113 250SL
1984 R107 500SL
1990 R129 500SL
DaveB
« Reply #5 on: February 22, 2023, 03:47:01 »
OK mine is different so no good for a template. The originals have a weak tab here - would be stronger if you make a separate tab spot welded or riveted on.
DaveB
ryan.mb
« Reply #6 on: February 22, 2023, 12:48:21 »
Thank you DaveB! When I will produce this part, then I will definitely take into account your suggestion!
Anyone else please, could you please share template of short version of Fuel Pump Shroud cover?
Ryan
1967 W113 250SL
1984 R107 500SL
1990 R129 500SL
Pinder
  • USA, NJ, Edison
« Reply #7 on: April 18, 2023, 02:23:45 »
Did you get any template? I am about to remove my fuel pump to check if my filter is clear.  I can make a paper template while i have the shroud removed but only if you have not had any response.
My car is a 1970 280SL with a short pump.
Regards
 Pinder
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #8 on: April 26, 2023, 00:28:23 »
Ryan, If you end up with a good drawing for manufacturing one, please share it with us.  If it's something I could hand to a local fabricator, I'd have one made.  OR, if you figure out how much it would cost, perhaps you can make a few extras to sell?
Pinder
  • USA, NJ, Edison
« Reply #9 on: April 26, 2023, 14:25:05 »
Does this help . From 1970 280sl paper tracing of the sides of the shroud.
Pinder
  • USA, NJ, Edison
« Reply #10 on: April 26, 2023, 14:35:27 »
Picture of one that I  traced
Raymond
« Reply #11 on: April 29, 2023, 12:19:41 »
I see Buds Benz has reproductions for $339.
ryan.mb
« Reply #12 on: May 04, 2023, 07:08:41 »
Hello @Pinder! I didn't get any notifications on new replays in this thread. My apologies for late replay. I didn't get any template, so Yours is just right on time and is very helpful, thank you very much!
Ryan
1967 W113 250SL
1984 R107 500SL
1990 R129 500SL
ryan.mb
« Reply #13 on: May 04, 2023, 07:55:28 »
Dear Pinder,
Would it be possible to add some extra measurements to your drawing? Please see picture I attached. Could you please also indicate what is the metal sheet thickness 1mm or 1,2 or 1,5? If possible could you still check what is outer and inner diameter?
Could you please help with one number? In your drawing top measurements from left to right are 76mm - 59mm - 104mm and what is the fourth number 85mm or 55mm?
Ryan
1967 W113 250SL
1984 R107 500SL
1990 R129 500SL
Pinder
  • USA, NJ, Edison
« Reply #14 on: May 07, 2023, 18:11:42 »
Ryan
Dimeter is 180mm if you put cut the template and join A and B points together.
The small hole at the bottom of the cover is 20mm.
4th number is 55mm.
Sheet metal thickness is 1mm.
Pinder
  • USA, NJ, Edison
« Reply #15 on: May 07, 2023, 18:23:55 »
Here some picture showing more measurements.
Pinder
  • USA, NJ, Edison
« Reply #16 on: May 07, 2023, 18:24:59 »
More pics
Pinder
  • USA, NJ, Edison
« Reply #17 on: May 07, 2023, 18:25:54 »
More pics
Pinder
  • USA, NJ, Edison
« Reply #18 on: May 07, 2023, 18:26:24 »
More pics
Pinder
  • USA, NJ, Edison
« Reply #19 on: May 07, 2023, 18:28:41 »
More pics
Pinder
  • USA, NJ, Edison
« Reply #20 on: May 07, 2023, 18:33:18 »
Ryan remember my template is show as the inside of the cover so if you were to cut it out you would move Point A and Point B towards you to make the cylinder shape. Also it is not a complete cylinder but distance from A to B is 123mm.
ryan.mb
« Reply #21 on: May 07, 2023, 19:18:59 »
Great! Thank you so much! Looks like I have all the measurements to make this thing. I will share my results back with community! Perhaps it will be useful to someone else  8)
Ryan
1967 W113 250SL
1984 R107 500SL
1990 R129 500SL
Pinder
  • USA, NJ, Edison
« Reply #22 on: May 08, 2023, 20:13:01 »
Also remember that 2 of the 3 tabs are welded on for some reason and one of them is bent at 90 degrees
