Author Topic: Identify prop/drive shaft  (Read 1461 times)
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
« on: February 23, 2023, 23:20:48 »
I am in need of help to identify the prop shaft that I just removed from my 230SL.  After the removal and during my inspection, I decided that it would be a good idea to replace the universal joints.  My universal joints are not held in place with spring clips on the top of the cap but clips under the yoke.  As I am am doing my rolling restoration, I have found parts that have been changes with non 230SL parts.
 Therefore, I feel that there is a good possibility that my prop shaft came from another model.
- Universal joints do not look like any sold for a 23SL
- This shaft has a slip joint next to the carrier barring.
- The only part number I can find in on a yolk starting that starts with 114
- There is a Mercedes star and B & H stamped on the end of the shaft
- The slip joint end has a fiber seal pocked to keep the grease in the slip joint
My goal is to find the universal joints that will fit this shaft.
« Last Edit: February 23, 2023, 23:26:34 by afibbe »
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
afibbe
  • 513-374-5600
Re: Identify prop/drive shaft
« Reply #1 on: February 23, 2023, 23:24:44 »
More Pictures
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
dirkbalter
  • USA, CA, Corona
« Reply #2 on: February 23, 2023, 23:35:58 »
Alex,
the 230 U-joints are secured with retaining rings were as the later (280's) U joints are peened to secure.
I have a 66 as well and can post some pictures for comparison later?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
  • USA, CA, Corona
« Reply #3 on: February 24, 2023, 01:00:46 »
Take a look. I rebuild it and had it balanced afterward.
« Last Edit: February 24, 2023, 01:08:49 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
afibbe
  • 513-374-5600
« Reply #4 on: February 24, 2023, 03:00:07 »
I’m a believer now. I have the correct shaft.
Thank you all.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
