Author Topic: Exhaust Heat Shields full set ho many?  (Read 3745 times)
joelpalmer
  • USA, PA, Philadelphia
« on: February 28, 2023, 22:06:26 »
Need to buy a full set of exhaust heats shields for out W113 250 SL (early build).
Starting point; how many are there and what are the locations? Need to be servicable and able to be refinished
Thanks in advance;
dirkbalter
  • USA, CA, Corona
Re: Exhaust Heat Shields full set ho many?
« Reply #1 on: February 28, 2023, 22:31:36 »
Take a look here:
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/49-exhaust-systems/49-a-exhaust-system-standard
That should give you an idea on what you need. I believe the rear shield was not used on the 280's.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
