Author Topic: Cold Start Injector issue  (Read 1670 times)
Brandini
  • USA, WA, Seattle
« on: March 03, 2023, 00:13:51 »
My car isn't starting and I think it may be related to the cold start injector. I took the cold start injector off and first tested the solenoid which is working fine. I also took the relay and cleaned the points and put it back on. I confirmed that there is fuel coming out of the fuel line. I cleaned the cold start injector including the points where it sprays out to ensure it isn't clogged.
Is there another reason why the cold start injector may not be functioning properly? Something internal in the injector itself? I did notice it was leaking fuel after I put it back on but think it may just be the rubber seal which I need to be replace.
I'm trying to decide whether or not to buy a new cold start injector or if it's a whole different issue.
Respectfully,
Brandon
« Last Edit: March 04, 2023, 16:47:30 by Brandini »
Brandon
1964 Mercedes 230SL - red
Seattle, WA
Re: Cody Start Injector issue
« Reply #1 on: March 03, 2023, 09:12:53 »
Take the little plug out just below the injector and see if there's vacuum there with engine running. If not then the injector is blocked.
« Reply #2 on: March 03, 2023, 17:49:01 »
Hi.  Did you see this recent thread?  Did you search for others?
https://www.sl113.org/forums/index.php?topic=36029.0
I see you're a full member, did you check Tech Manual?
https://www.sl113.org/wiki/Restricted/Engine-starting-aid-tour
These (and Colin's advice) should help you out.
ctaylor738
  • USA, VA, Falls Church
« Reply #3 on: March 03, 2023, 18:01:55 »
Maybe the thermo-time switch has packed it in.  It provides ground to the relay when cranking for a cold start.  You can test it by connecting a test light or meter to the electrical connection on the valve and ground.  You should see voltage when you crank a cold engine.  If no voltage, test terminal 85 on the relay harness for ground when cranking.
Maybe the valve is plugged.  If the valve is getting power, take it off the manifold and re-connect the power and fuel lines.  Run a jumper to ground the valve.  Put the valve in a plastic bag, crank the starter, and see if it sprays.  If it doesn't you need a new or rebuilt valve.
Good luck,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
« Reply #4 on: March 04, 2023, 04:47:53 »
With the engine running at idle, energize the wire going to the CSV. If the engine falters from the excess fuel, then the valve is functional. Next use a test light to see if it functions when it should (cold starts etc.)
Brandini
  • USA, WA, Seattle
Re: Cold Start Injector issue
« Reply #5 on: March 04, 2023, 16:46:38 »
Thanks everyone for your help and advice. I think I've determined that the TTS is bad and have ordered a new one ( Part # 91161711700 ) as recommended by others on the forum. Once I receive I'll replace and report back.
Brandon
Seattle, WA
