Author Topic: Pertronix & Timing?  (Read 3608 times)
Pertronix & Timing?
« on: June 24, 2005, 05:37:22 »
For all that have the Pertronix installed; what is your timing set at?  What have you found to be the "sweat spot"?
I currently have mine set at ~29 BTDC @ 3000 rpm (mb factory spec @ 3000 is 25-30).  Seems to run well. .. still have a slight muffled sputter when I let off the accelerator at the higher rpms....
Note: my magnet has the white dot, #18673
Memphis, TN.
1997 E320
Malc
Re: Pertronix & Timing?
« Reply #1 on: June 24, 2005, 08:12:46 »
Splutter could be due to running slightly too weak, check the colour of your plugs before assuming your timing is out
Black - too rich
light brown, sand colour just right
white, glazed look - too weak
HTH
Malc
