Author Topic: Lower front control arm rubber stops  (Read 1453 times)
frostpinfold
  • United Kingdom, England, Bridport
« on: March 09, 2023, 14:01:45 »
I have fitted new king pins. The rubber stops for the lower control arms were badly damaged so I removed them. I have new rubber stops but cant fit them, they wont enter the housings on the arm.
Does anyone have a tip as to how to get them into the housing. They are about 0.100 inches diameter bigger than the housing
Rob
Rob
Duncan200
  • Just started my Restoration
Re: Lower front control arm rubber stops
« Reply #1 on: March 09, 2023, 22:17:40 »
Hi Rob,
I used a bit of rubber grease and brute force.
I found getting the old ones out more difficult, compressed air is your friend when wanting to remove them.
If it’s a bit rusty in the holes, I suggest cleaning it up with a wire brush/wet & dry and giving it a coat of primer and satin black.
Doug
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day it will be back on the road in all its glory.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
TJMart
  • USA, NC, Matthews
« Reply #2 on: March 10, 2023, 16:43:12 »
Rob
Rob, I assume you are talking about the bullet shaped hard rubber stops. I used a product called P-80 Emulsion. Use it sparingly on the lower part of the stop. I used a flat molding pry bar. The trick is to apply down word pressure equally on the top point of the stop because they fit very tightly. Once you get equal pressure they will slide right in. The P-80 dries so the stop is secure.
Tony
1970 280SL, 4 Speed
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
« Reply #3 on: March 15, 2023, 16:48:04 »
I had power coated my lower arms and my space for the rubber stops got even smaller. I used some lubricant and a bar clamp. I would squeeze the clamp as much as I could and wiggled it back and forth.  Then released the clamp and started again.  Millimeter by millimeter it worked its way in.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
