Author Topic: BOSCH injection pump  (Read 3550 times)
SoloTech
« on: March 12, 2023, 21:02:34 »
I was reading a very old thread that seemed to match an issue that I have on our 1997 Scania K93 bus, converted to a motorhome.
A reply, in https://www.sl113.org/forums/index.php?topic=333.0, mentions an article link, but it pops an error when I click it. http://sl113.org/articles/engine/fuel_injection.asp
My problem is that I've found the remainder of an o'ring inside the governor assembly and have no idea where it came from.
The pump is a BOSCH PE6P120A320RS7138-10.
Originally, the pump was spewing oil out of a small hole, just behind the engine stop linkage. I patched the hole, then removed the 22mm oil filler bung to see what had caused the oil spill, discovering the partial o'ring.
I still have no idea what caused the hole to be punched through.
Would any have any info?
Thanks.
Re: BOSCH injection pump
« Reply #1 on: March 13, 2023, 12:08:38 »
Contents of these articles have moved to the Technical Manual. You would need a full membership to read those. I doubt you'll find the information you are looking for in our Tech Manual however, as it is limited to fuel pumps and fuel injection pumps specific to our cars.
