Author Topic: Fixing a long standing engine oil leak  (Read 1508 times)
Pinder
  • USA, NJ, Edison
« on: March 12, 2023, 23:37:09 »
Since rebuild the engine back in 2016 I have been chasing a slight oil leak. After driving the car I would notice two small oil drops on the bell housing at the bottom of the engine. I was convinced this was a rear main seal leak and thought maybe during the rebuild I didn’t get it right .  This actual cause of this leak I finally figured out was a minor leak at the valve cover caused by the valve cover not being complete flat. It had a few low spots such that I could put feeler gauge in some areas while I had it on a flat granite countertop. I corrected this and re installed and so far so good , engine leak is gone.
See picture attached on how I flattened the valve cover.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder
  • USA, NJ, Edison
Re: Fixing a long standing engine oil leak
« Reply #1 on: March 12, 2023, 23:39:22 »
3 sheets of 120 grit sandpaper and move the cover back and forth until the bottom of the cover is shiny
Kevkeller
  • USA, HI, Honolulu
« Reply #2 on: March 13, 2023, 00:07:05 »
Good thinking. Thank you.
1970 280 SL
« Reply #3 on: March 13, 2023, 03:48:46 »
That doesn't always work. If the top of the cylinder head is warped, odds are the valve cover will warp with it. Changing to a perfectly flat valve cover may make it leak even worse.
I would check the top of the head to see if it's flat and determine from there. We had to fix the same issue recently and did that by cutting a long O-ring in half and placing it into the valve cover gasket at both ends so the gap would close up.
Pinder
  • USA, NJ, Edison
« Reply #4 on: March 13, 2023, 04:03:21 »
That’s a really good point Dr Benz. I actually got the idea to do this from an old Post you wrote about keeping the heads Matched to the valve  covers. But when I did the rebuild I sent the head out to be machined . But not the valve cover.  It seems to have fixed the issue. See how it holds up in the hot weather and oil thinning but I am optimistic. I took the car out for a long drive on a wonderful day here in NJ.
I was thinking of using some type of sealant on the gasket but wanted to try this first.
Regards
Pinder.
