Need to know something? Search the Technical Manual first, then Search the Forum. Post a question last!
John,I have had the same problem with the passenger visor.The small sleeve that wraps around the shaft in the visor for some reason doesn’t grip the shaft when the screw is tightened to bring the two halves together.I inserted a small piece of metal rod between the original shaft and the encircling metal to give it more grip and then tightened it with some success. Garry
Frank,As a matter of interest where did you get your rhd visors from. I purchased new ones but lhd ones were delivered and after the cost of getting them i have not been prepared to pay another $500 to start again. The new ones also had the slip problem. Garry
