Author Topic: Pillar seal replacement  (Read 2054 times)
mauro12
  • Italy, Sicily, Messina
« on: March 17, 2023, 12:20:54 »
Hello guys , I need to replace the pillar seal next to the windshield . I wanted to know how difficult is it and how to do it . Do you need to glue the seal or just put in place with a spatula ? Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Re: Pillar seal replacement
« Reply #1 on: March 17, 2023, 13:54:08 »
It's been years since I did this, but I am pretty sure I did not use glue and was able to securely fit new seals just pressing them in as you say. The main trick was to make sure I trimmed the new pieces to snugly fit the body/top.
mauro12
« Reply #2 on: March 17, 2023, 15:11:59 »
You don’t need to put new clips to fit in place the seal ?
Mauro Pisani
« Reply #3 on: March 18, 2023, 03:00:57 »
Maybe we're not talking about the same seals - the ones I was referring to are the 'uprights' on the window frame, that the door glass fits into. The seals slide into channels and although I suppose they could be glued in, mine have stayed put without glue for at least the past 18 years.
mauro12
« Reply #4 on: March 19, 2023, 16:01:35 »
I mean this seal . I guess glue is not needed right ? And another question about the hard top from seal . Is the same procedure like for the soft top front seal ?
Mauro Pisani
dirkbalter
  • USA, CA, Corona
« Reply #5 on: March 19, 2023, 16:19:29 »
I am just replacing the seals in your pic as well. They are sliding in / out relatively easy.
I will add a few drops of trim- glue to keep them securely in place.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Benz280
  • USA, NJ, Jersey City
« Reply #6 on: March 19, 2023, 16:25:15 »
Did mine, very easy. Existing clips worked fine .
Rubber seal was a bit longer than needed, had to cut with a razorblade.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
dirkbalter
  • USA, CA, Corona
« Reply #7 on: March 19, 2023, 16:57:16 »
Help me out please. What do the clips look like? I might be missing them.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #8 on: March 19, 2023, 17:16:40 »
Dirk,
there are two types of clips. There is a photo in this post showing the 2 clips in the channel (they insert into the larger hole in the channel):
https://www.sl113.org/forums/index.php?topic=14480.msg98869#msg98869
 And then there are triangle corner clips at the bottom:
https://www.sl113.org/forums/index.php?topic=8610.msg55973#msg55973
mauro12
« Reply #9 on: March 19, 2023, 17:26:34 »
is it a good idea to buy these clips new ?
Mauro Pisani
dirkbalter
  • USA, CA, Corona
« Reply #10 on: March 19, 2023, 20:49:48 »
Dirk,
Thanks Alfred.
Missed it. I guess that takes care of the glue.I have to get some.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
