Author Topic: Stamp on Engine - SE A?  (Read 1720 times)
tarheel
  • USA, NJ, MULLICA HILL
« on: March 19, 2023, 19:46:22 »
Hello
I have a 1969 280SL.
The prior owner assured me that the engine was original
Yet whilst changing the plugs and wires today I discovered 280 SE A stamped along side of engine nearest firewall a drivers side (LHD).
Clearly it’s a W113 and not an SE!
How do I confirm this is the original engine?
Did they put SE engines into SLs or was this a replacement engine?
Love her in any case!
Jack the Knife
  • USA, FL, Vero Beach
Re: Stamp on Engine - SE A?
« Reply #1 on: March 19, 2023, 20:03:04 »
I've never figured out what the /A stands for, but what's the number on the block? If it says 130.983, that's a 280SL engine. If it says 130.980, that's for a sedan. There will also be an engine number after that which should match the number on your data card, if you have it. If it is a sedan engine, you may want to check the distributor and camshaft that were used, as those used in the SL gave it a bump more horsepower. Also, you'd want to note if it's an early or late model M130, as there are differences.
1964 230SL
2015 G550
« Reply #2 on: March 19, 2023, 20:32:48 »
Sort of. Only the euro 280 SL engine had a bit more HP. /A indicates later USA version engine, kind of like /8 indicates 1968 or later build. Sedan engines and SL engines are more similar than they are different.
Jack the Knife
« Reply #3 on: March 19, 2023, 20:50:37 »
So it really does stand for USA? Interesting. So what all were the differences between the US and ROW engines? Was it just the early emissions stuff?
1964 230SL
2015 G550
DaveB
« Reply #4 on: March 19, 2023, 20:53:01 »
Yes, agree, 280 SE/A on the head is normal, seen plenty like that.
DaveB
'65 US 230sl 4-speed, DB190
« Reply #5 on: March 19, 2023, 21:03:13 »
I think so. The block, cam, cam bearings, head, ignition system and throttle valve were some of the changes. The late Euro engines stayed with the cast iron distributor and the early systems.
MikeSimon
  • USA, OH, North Royalton
« Reply #6 on: March 21, 2023, 15:31:59 »
Sorry to contradict an expert. The /A on the cylinder head does not stand for "America". During my extensive research about cylinder heads (my 1971 German spec 280SL has a head which is not shown in our head chart in the Tech Manual, with the ID 280SEL/SL and the number 130 016 17 01) I found that the SE/A head was installed in a lot of European M130s, both 280 SE and SL.
What the /A stands for I don't know, though.
Looks like the OP's engine does not have a number on the block.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
