Author Topic: Hood Safety Catch help needed  (Read 2216 times)
Brandini
  • USA, WA, Seattle
« on: March 22, 2023, 14:24:00 »
I seem to be missing the bracket or body plate where the hood safety catch latches into. I've searched the forums and vendor websites but can't find it. Can someone tell me what to search for or send me a link to where I may purchase it? Thanks in advance!
Brandon
1964 Mercedes 230SL - red
Seattle, WA
BobH
Re: Hood Safety Catch help needed
« Reply #1 on: March 22, 2023, 15:32:08 »
Hello Brandon, there should be a bracket where the relays bolt to, this would have the body/paint number plate fixed to it and the windscreen washer pump, there's a square hole that the safety catch hooks into.  I'm not sure from the angle of your picture if you're missing this bracket, or what your relays are fixed to?  There are pictures on this link.  Even early cars must have had this bracket, for the catch to hook into.  Let us know what you find out
https://palmbeachclassics.com/body-and-paint-number-plate/#:~:text=If%20a%20W113%20was%20delivered%20without%20the%20optional,softtop%20folded%29.%20The%20possible%20codes%20are%20as%20follows%3A
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Brandini
  • USA, WA, Seattle
« Reply #2 on: March 23, 2023, 00:04:01 »
Thank you for the reply - yes, I am missing the bracket that the relays affix to. Currently they are held in place by a few screws to the fender. Through the link you provided I was able to figure out what it's called and found one here:
https://www.niemoeller.de/en/w113/w113/B042/621/d62260-holder-relay-a-baffle-left
I wonder how I could get the body and paint number plate fabricated to add on top the the bracket?
Thanks again!
Brandon
Seattle, WA
dirkbalter
  • USA, CA, Corona
« Reply #3 on: March 23, 2023, 01:46:52 »
Brandon,
contact for the plates is below.
His name is Memmo. Easy to deal with. I believe he is also a member here.
http://www.pagode-markt.de/
« Last Edit: March 23, 2023, 01:55:11 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Brandini
  • USA, WA, Seattle
« Reply #4 on: March 23, 2023, 03:00:28 »
This is great thank you so much!
Brandon
Seattle, WA
Brandini
  • USA, WA, Seattle
« Reply #5 on: April 06, 2023, 01:24:39 »
I finally got the relay holder in today. Could someone tell me how this is installed? Is it welded or screwed in? Maybe someone could send a picture of theirs?
Brandon
Seattle, WA
Brandini
  • USA, WA, Seattle
« Reply #6 on: April 06, 2023, 02:51:59 »
I am also missing the metal piece that is welded to the car that the plastic bracket screws into. Does anyone know where I might find this metal piece?
Thanks in advance - Brandon
Brandon
Seattle, WA
WRe
« Reply #7 on: April 06, 2023, 04:59:27 »
see here no. 18: https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/62-body-frame-panelling/62-body-front.
...WRe
« Last Edit: April 06, 2023, 05:09:21 by WRe »
WRe
« Reply #8 on: April 06, 2023, 05:06:55 »
here you can find a lot of body shell reference photos: https://www.sl113.org/forums/index.php?topic=20285.msg143616#msg143616
...WRe
« Last Edit: April 06, 2023, 05:14:51 by WRe »
Brandini
  • USA, WA, Seattle
« Reply #9 on: April 06, 2023, 14:36:01 »
...WRe
Thank you WRe - extremely helpful!
Brandon
Seattle, WA
