Author Topic: Carrier Arm Set-Up  (Read 1288 times)
Harry
  • USA, TN, Knoxville
Carrier Arm Set-Up
« on: March 29, 2023, 01:51:57 »
The BBB instructs to set the distance from the pinion flange face to the upright arm as 158 +/- 1 mm.  It also says to set at 90 degrees to the left axle.  So my question is the measuring point on the arm for the 158 setting.  The Carrier arm is a curved surface, I.e. there doesn’t seem to be a straight/flat surface?  What/where is this measurement made from?
I guess I’ll use a level and right angle to set the 90 degree dimension.  Advice?
Thank you,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
dirkbalter
  • USA, CA, Corona
Re: Carrier Arm Set-Up
« Reply #1 on: March 29, 2023, 15:05:48 »
Harry,
For what it's worth, I measured  the 158 dim at the end of the radius in the upper area, close to the stud. If I remember correct, it becomes somewhat flat or straight.
On the 90 degrees, after setting the axle tube perfectly horizontal, I also used a level in conjunction with a square, for the angle.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Harry
« Reply #2 on: March 29, 2023, 18:14:05 »
Thanks again Dirk!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
