Author Topic: Wiper Motor Parking  (Read 2894 times)
NigelStn
  • United Kingdom, England, SHARDLOW
Wiper Motor Parking
« on: March 29, 2023, 17:29:53 »
1969 280SL RHD
My wipers stop where they end up when they are switched off. I've tried this with the wipers disconnected from the motor and it stops in random places
I've cleaned the contacts, since the photo.
Could the issue be the motor wiring? The last photo shows that the connector box has been opened by a previous owner, which makes me suspicious.
I'm a new member and this is my first question, so sorry if I've missed something!
I've searched the technical manual and can't find the answer.
BobH
Re: Wiper Motor Parking
« Reply #1 on: March 29, 2023, 17:59:47 »
Hello, as well as the tech manual, just use the general search function above, most questions have been asked and answered before.  I found this post with the same problem
https://www.sl113.org/forums/index.php?topic=20233.msg143440#msg143440
The advice is always to take care when working under the dash and isolate the supply before putting your hands anywhere near the wiper mechanism
Good luck
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
NigelStn
« Reply #2 on: March 29, 2023, 18:11:49 »
Thank you Bob
I had seen this post, which is slightly different to my issue.  My motor stops turning as soon as the wipers are switched off, which makes me think that the motor is wired incorrectly.
BobH
« Reply #3 on: March 29, 2023, 19:21:07 »
Have a look on here for details of the wiring to the wiper motor plug.  Seems pin 4 should have a permanent +ve supply from the fuse, i think this is for the wiper blade parking, but have a read.  Be careful as this post discusses pagoda's and other cars
https://www.sl113.org/forums/index.php?topic=28526.msg206055#msg206055
UK delivered RHD
Blue soft top
Blue leather
« Reply #4 on: March 29, 2023, 19:46:04 »
I thought mine was the only Pagoda with the "intermittent wiper" option. I have never tracked down why (because it rarely happens) but my wipers sometimes jump up a bit. And parking them in their proper resting spot requires perfect timing when hitting the stalk mechanism.
Keep us posted on the remedy.
JH
NigelStn
« Reply #5 on: March 30, 2023, 08:11:30 »
Thank you
I think that I have a W111 wiper motor!
mnahon
  • Canada, QC, Montreal
« Reply #6 on: March 30, 2023, 10:38:38 »
That's correct, you have the wrong wiper motor. That's a W111 (5-pin) motor. The Pagoda wiper motor has 4 pins. It looks very similar but functions differently. While the W111 motor bolts into and plugs into a Pagoda, it will not park properly.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
BobH
« Reply #7 on: March 30, 2023, 13:41:29 »
JH
Hello James, assuming you have the correct motor, have you checked for the permanent +24ve supply to pin 4?  perhaps a bad contact in the plug or poor solder joint
UK delivered RHD
Blue soft top
Blue leather
« Reply #8 on: March 30, 2023, 17:35:38 »
Bad assumption this time, Bob.  :-)
I actually see six pins.  Is one just for making sure the plugs are oriented properly when connecting?
BobH
« Reply #9 on: March 30, 2023, 18:12:22 »
Hello Rodd, my reply was directed to James who has a similar problem, we don't know what motor he has installed, hence the suggestion
UK delivered RHD
Blue soft top
Blue leather
BobH
« Reply #10 on: March 30, 2023, 18:49:07 »
Yes, the small pin is just a locator
https://www.sl113.org/forums/index.php?action=dlattach;ts=1578840191;topic=28526.0;attach=243206
UK delivered RHD
Blue soft top
Blue leather
« Reply #11 on: March 30, 2023, 21:30:40 »
Thanks Bob. I am pretty confident mine is the correct one. I will check connectors.
NigelStn
« Reply #12 on: April 12, 2023, 13:43:04 »
Thank you everyone for your help, I've now sourced the correct wiper motor, though have to replace the connector.
I'm a little confused with the wiring as in the technical manual it shows:
PIN 1 = BLACK/GREEN
PIN 2 = BLACK/WHITE/PURPLE
PIN 3 = BROWN to GROUND
PIN 4 = BLACK VIOLET to VOLTAGE FUSE 2
The pin 3 on my motor does not appear to be earth (see photo)
Am I missing something?
BobH
« Reply #13 on: April 12, 2023, 15:37:04 »
Hello, i saw that in the tech manual, not sure why it's different from the wiring diagrams
The correct connections are:
Pin 1 - black/violet/white - to relay
Pin 2 - brown - earth
Pin 3 - black/violet/green - to wiper switch
Pin 4 - black/violet - to fuse 2
UK delivered RHD
Blue soft top
Blue leather
NigelStn
« Reply #14 on: April 12, 2023, 16:11:43 »
Thanks for a fast response Bob
That's what I suspected, but needed some reassurance!
mBdrvr
  • USA, PA, Bethlehem
« Reply #15 on: May 02, 2023, 23:29:10 »
My W111 250 SE cabrio wipers park "arms folded" as can be seen in the picture even though they are not parked correctly. I believe the sedans do the same.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
cfm65@me.com
  • Cape Town, South Africa
« Reply #16 on: May 03, 2023, 06:31:21 »
Tks Paul,
My mistake, post removed. I had a Coupe as well as a Cabrio some time ago, which I both restored, can’t believe it got I wrong.
Apologies once again.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
mBdrvr
« Reply #17 on: May 03, 2023, 20:26:07 »
No problem. I haven't investigated how to get the arms to park in the right places. They also don't park automatically after I removed and reinstalled the washer foot control. I need to figure that out.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
