Author Topic: Nose panel patch  (Read 3123 times)
Frank
  • USA, NY, Delmar
Nose panel patch
« on: March 30, 2023, 18:30:14 »
Wondering if anyone has a damaged /old nose panel they’d care to part with.  Specifically looking for a patch for the section attached to the bottom of the driver side headlight bucket and fender.
Re: Nose panel patch
« Reply #1 on: March 30, 2023, 20:32:58 »
I believe repair panels are being offered now for this area, try the usual suppliers like SLS:
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/62-body-frame-panelling/64-panelling
« Reply #2 on: March 31, 2023, 17:32:15 »
Frank
  • USA, NY, Delmar
« Reply #3 on: April 01, 2023, 00:12:27 »
Thanks for the info.  I’ve had good luck with K&K but no one seems to have the patch panel I need.  There are available patch panels for the front fender but the section I need is part of the nose panel.  I hate to purchase the whole panel to cut out the patch, and replacing the entire panel is much more than I care to get into at this point.  Hence, I was hoping to find/purchase a discarded used panel.  I appreciate any and all input.
Thanks.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #4 on: April 03, 2023, 21:21:14 »
Go check out your local hot rod shop.  A metal fabricator should be able to replace portions of your nose.  The Mercedes Benz metal in our cars is thick compared to modern cars so a bit more forgiving.  The hot Rod guys (and gals) would know about work hardening and how to create a new piece to weld in.
I don't think it would be cheap though.
I made wooden upper and lower dies to fit in my hydraulic press to form small patch panels to replace portions of the rusted out bed of my old pickup and I probably spent 2 hours just making the dies to get the right dimensions for the ridges after being squished.  And this had no complex curves or angles like a nose.
Metal does funny things when getting squished and formed so you need a real craftsman (or lots of bondo).
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
