Author Topic: Valve cover leak  (Read 6471 times)
haris
  • United Kingdom, England, Manchester
Valve cover leak
« on: April 02, 2023, 11:57:51 »
Hi all,
I have been shamelessly using the resources here for my 280SE as there's such good info on the site for M130 engines/gearboxes  :-X
I have been trying to solve a valve cover leak that just doesn't stop, it will leak out from the top bolts and near the oil filler cap, I have put on a new seal for the valve cover, new washers for the bolts, new seal for the oil cap but as soon as I take it for a drive it will leak literally about 100-200ml even on a short drive.
I have tried adjusting the how the cover sits, how tight the bolts are, I am now at the point where I think I just need to take it off again, get a new gasket from Mercedes, any washers/bolts etc and start again.
Has anyone else ever experienced this? Have you got any tips?
Really getting frustrated now  :-\
WRe
Re: Valve cover leak
« Reply #1 on: April 02, 2023, 12:33:32 »
Hi
have you checked the valve cover for tiny/hairline cracks?
...WRe
MikeSimon
  • USA, OH, North Royalton
« Reply #2 on: April 02, 2023, 12:37:01 »
While I have no explanation for the filler cap leak after you installed a new seal, over-tightening of the mounting bolts can result in deformation of the brackets which then results in the valve cover no longer sitting properly. What seals do you use for the bolts?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
DaveB
« Reply #3 on: April 02, 2023, 13:26:12 »
I guess these leaks could be a symptom of excessive crankcase pressure. Hopefully not.
DaveB
'65 US 230sl 4-speed, DB190
Ed Riefstahl
  • USA, PA, North East
« Reply #4 on: April 02, 2023, 13:46:31 »
Hello haris,
Make sure you have washers under the valve cover bolts. I use brass washers. I also had to recently replace the rubber on the filler cap. The rubber became dried out and I was having the same issue.
Not sure the year, but make sure the engine is venting properly. My 1966 230 SL has a breather on the dipstick. MY 1970 280S does not.
Good luck,
Ed Riefstahl
Erie, PA
1966 230SL (Ms Magoo)
1970 280S (Miss Daisy)
1989 300SE (Majestic)
1999 BMW Z3 5 speed
1991 BMW 318I 5 Speed
1997 Toyota Paseo Convertible - Red 5 speed (have you ever seen one?)
1997 Ford Ranger step side (Mater)
2023 Mazda CX 5
« Reply #5 on: April 02, 2023, 18:17:46 »
I am also thinking crankcase pressure. Oil normally would not force itself out through the valve cover top?
« Reply #6 on: April 02, 2023, 21:00:43 »
There is a baffle under the valve cover that is riveted to the valve cover. I've seen where these rivets can come loose and start to leak so you should check for that.
« Reply #7 on: April 03, 2023, 01:57:30 »
Check the vent tube all the way from the rubber vent boot on the valve cover to the intake manifold. If it becomes blocked your engine will blow oil out wherever it can.
« Reply #8 on: April 03, 2023, 08:40:55 »
It's very important to get the basics right before anything else.
The rubber gasket is re-useable as long as it is soft and compliant without any sign of cracking if bent sharply.
The seals around the bolts are special crush washers; normal flat copper, brass or aluminium seals will not suffice. It's also very important not to overtighten these bolts. If you don't have a torque wrench then use "NVT" setting on your ratchet.
However, if oil is eminating from the oil filler cap despite fitting a new seal then it is most likely that you have excessive crankcase pressure. This might be caused by a blocked ventilation system. The easy way to check is to remove the hose from thew rocker cover and run the engine. If you feel or see excessive venting then you have identified your problem. If not then probably the venting system is blocked.
« Last Edit: April 04, 2023, 07:18:33 by stickandrudderman »
haris
« Reply #9 on: April 03, 2023, 19:32:38 »
Brilliant thanks for the help, will be investigating this weekend. I have a feeling the vent is blocked. Will report back.
haris
« Reply #10 on: April 14, 2023, 18:35:31 »
So two things are broken.
The gasket was split on the inside
One of the towers that holds down the cover is broken.
Any ideas where I can get another one?
Pinder
  • USA, NJ, Edison
« Reply #11 on: April 14, 2023, 19:01:55 »
did you check on ebay?
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
BobH
« Reply #12 on: April 14, 2023, 20:18:09 »
Do you mean the bracket that the cover bolts down onto?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Pinder
  • USA, NJ, Edison
« Reply #14 on: April 14, 2023, 22:06:34 »
not 100% sure it will fit w113 although it says that in the heading.
haris
« Reply #15 on: April 15, 2023, 06:12:42 »
Brilliant thank you! Won't arrive in the UK until early May though.
Managed to find the part no I need so will have a search here in the UK.
1150160038
For anyone who comes across this thread in future when searching.
BobH
« Reply #16 on: April 15, 2023, 07:24:32 »
If you have no luck in the UK, there's a member/vendor selling some.  It's an old post but he's also listed these on Ebay, so it looks like they're still available
https://www.sl113.org/forums/index.php?topic=31680.0
Just found the SL shop have them
https://parts.theslshop.com/clamp-1150160038/
« Last Edit: April 15, 2023, 07:37:50 by BobH »
UK delivered RHD
Blue soft top
Blue leather
WRe
ejboyd5
  • Southold, NY
« Reply #18 on: April 15, 2023, 11:00:01 »
What is an "NVT" setting?
Pinder
  • USA, NJ, Edison
« Reply #19 on: April 15, 2023, 13:17:31 »
Not Very Tight
haris
« Reply #20 on: April 15, 2023, 17:36:05 »
Managed to find some from a local guy who specialises 60-90s Mercedes which is handy.
Means I can actually go to the Bicester Scramble show  8)
Thanks for the help everyone!
