Author Topic: 230SL Left front Disc Backing Plate  (Read 2596 times)
Duncan200
  • Just started my Restoration
« on: April 06, 2023, 08:46:08 »
Hi All,
Looking to buy a left front disc backing plate for a 230. OE number is 1114200044 and yes they are different to the 250/280.
If anyone has one lying around in reasonable condition, can you please let me know? As long as it doesn’t have a hole in it or is damaged/bent, like mine.
Thanks Doug.
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day it will be back on the road in all its glory.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Brennie
Re: 230SL Left front Disc Backing Plate
« Reply #1 on: April 29, 2023, 15:23:33 »
I’m looking for a right hand side too..
Also early 230SL .. if anyone has one, I’d be most grateful..
Good luck with your search Doug
Duncan200
« Reply #2 on: April 30, 2023, 00:25:24 »
Hi Brennie,
Thanks for the kind thoughts.
I ended up welding up the hole in mine and panel beating it as best as I could to get it looking reasonable. I subsequently fitted it back on the car as I received no responses on here and I couldn’t justify spending €120 + shipping from Niemoller with the thought of it showing up incorrect.
I wish you all the best in your search.
Doug.
Brennie
« Reply #3 on: May 01, 2023, 15:07:34 »
Thank you Doug
I’ll keep looking..
« Reply #4 on: May 01, 2023, 15:32:26 »
I probably have some around here. Will look this week.
Brennie
« Reply #5 on: May 07, 2023, 15:14:05 »
Thank you.. that would be great…
Duncan200
« Reply #6 on: May 21, 2023, 10:37:18 »
Hi Dan,
Did you happen to find any backing plates laying around?
Thanks Doug.
« Reply #7 on: May 22, 2023, 15:28:38 »
Hi Dan,
Thanks Doug.
I need to remove one and see if it can be used. Should know soon.
« Reply #8 on: May 24, 2023, 15:59:30 »
I have some. Will remove today and inspect for condition.
Duncan200
« Reply #9 on: May 25, 2023, 07:23:19 »
Great, thanks Dan.
